6700xt General Discussion
It’s just in case nothing works. Has you can see i am not using those specs. You are right.
I testie hiveon with flexpool, the latter is better, it still varies a lot, I look from time to time here: AMD RX 6700 XT calculadora de minería ⛏️ | minerstat
Mvdd is at least lower than others
gminer v.2.70
regards.
rx 6700 xt sees hiveos and doesn’t dig. On other cards (3090 and rx 6600 xt it prevents it from digging. When 6700 is removed, the others continue to dig. Does anyone know about it? Driver A20.40 (5.11.0825) Please help!
Hi all.
I have 6700xt asrock challenger oc
Mining 47mh/s-47.3mh/s with srbminer
Settings
Core 1100mhz 690mv
Memory 1075mhz
Power limit -30%
Consuming 80w
Hi, the 3rd card doesn’t seem to work (6700 xt) as seen in the photo. but the fan is spinning and the rgb lights are on. can you help?
Update the os
hive-replace -y —stable
how will I do?
Greetings to all.
I am glad to be a new member of the forum.
Im interested in what is the SoC VDDmax for rx 6700XT?
I’m already looking forward to the answer.
Why is there a space between ? all space during = 10 min.
Thank you for your information.
So this is my settings:
And i get those results:
So are those good settings?
Because if i underclock more, my thinking is thaht the reported hashrate and hashrate by the pool having to much differance in hash ( real hash) by the pool.
Am i wrong?
Has anyone observed yet?
the pool hash rate will go up and down and overtime the average pool hashrate will essentially be your reported.
thats what ive found at least.
you are using way too much power for mining
hello everyone!
anybody have stable work with rx6700 sapphire nitro+ or red devil?
I use:
0.6-210@211025
5.4.0-hiveos #140
A20.40 (5.11.0701)
nbminer ver 39.2
46.5mhs too few. I want 47 and voltage under 100w
pls do not recommend TeamRedMiner.
normal hiveon cuts, look at it from the pool the cuts should not appear
test with core 1180, vdd 650, vddci 700, mvdd 1260 , nbminer aprox. 47 mhs
yo guys, I just tried my 2 6700xt on teamblackminer, 50 mh O.O can be real?
With these settings i get 46,30 mh/s on NBMINER.
Smemorando : Try to change to nbminer.
Registers the 50 mh / s in the pool?
