These are the numbers that I get from my cards:
hello there,
are you using a gminer? or else? i want to try this setting
as someone said, on a published video, about two mineiros, it is not unstable, it is running at about 14h stable…but I would like to improve the OC… any suggestions?
NBMiner
1st nbminer and 2nd gminer…
Can you show print of hiveos and pool?
I trying 2 miners and the pool don’t like
The test that I did hiveon had more shares but paid less eth / day, I recommend you try two pools
Now I use Binance pool.
Has anybody compared other pools to know which is better? Ethermine, Nanopool, HiveOs…? Any advice? I don’t know if the location is important, I live in Europe.
Thank you.
ethermine too much rejects, binance pool rejects too
flexpool more comfort for me atm
ps my location Europe
In Binance I have 0 rejections…
What cards do you have?
Edit: Sorry, I’ve just read a previous post of you explaining your rig.
Very weird. First, I would try to swap it with another, just to see if it is the same situation. Maybe is the pcie port, maybe a connection, maybe the card…
How have you got on running two miners at the same time?
120 watts is a lot. 6700, depending on the vendor, can give 47mh with a consumption of 83 to 97 watts
