@0Lucifer0 Just created an account to thank you mate!
Just got myself a PowerColor RX Vega 64 and have tried numerous settings but never got it to work as well as my Asus Strix RX Vega 56…I would get close (around 50-51) but it was never stable.
I force flashed it with the PowerColor 56 firmware and applied your straps and timings and now it performs exactly like yours. Now I have to test them both on the same rig and see if they will both maintain these hash rates. Just for the record, I am using the latest version of Teamredminer (I think it’s
0.8.2.1)
EDIT: As I was writing this, the rig crashed - approx 1 hour after applying these lol.
In any case, you have set me on the right path and I am experimenting around these values. I am currently using Core: 1050 VDD: 850 MEM: 1000 to see how it goes. These settings coupled with your straps are giving me 52.90-53.00
The important thing to note - and this is something that I have seen in many videos and I have experienced first hand - is that these settings do not work from a cold boot, at least for me.
I have to:
- Unset the flight sheet and the OC settings before booting up the rig so it doesn’t start anything.
- After it boots up and it’s idle, I enter the straps through the command line (amdmemtweak --gpu 0 –CL 20 --RAS 26 --RCDRD 12 --RCDWR 12 --RC 38 --RP 12 --RRDS 3 --RRDL 5 --RTP 6 --FAW 12 --CWL 8 --WTRS 4 --WTRL 9 --WR 13 --REF 24000 --RFC 239)
- I apply the flight sheet and let the card start hashing with default settings for a couple of minutes
- Apply the OC
If I do a cold start with OC’ed settings, my card goes into a frenzy and stops working for 10-15 minutes.
If someone knows a way to overcome this, please feel free to chime in. I am relatively knew to this, so any info helps.
