I tried lolminer 1,40 but this crashed every minute, now i go back to lolminer 1.39 and this works fine. Somebody else have this?
These are my oc settings
Any problems with OKEx?
My is crashing every 10 or so minutes on 1.40, will try as well 1.39
If you do about 1.80 euros ETH in 12 hours, I assume about 90 MH/s as with a RTX 3080 ⦠that is, with TON we would be at an equivalent output of about 4.2 GH/s and therefore at least 1.85 euros per 12 hours. If you only make just under 0.30 euros, your problem lies completely elsewhere, but not in the hashrate.
OKEx has since morning problems with TONCOIN⦠not sure if they fixed it meanwhile.
im at 3.2gh/s like i said in my earlier post and still at 0.32 tons according to the bot after 14h of mining i switched back to whalestonspool still same problem
lolminer is working fine and everything is up to date -_-
Even with 3.2 GH/s you would earn 1.85 Euro in 12 hours before power costs (in middle).
As I said before, these are no P(ay) P(er) S(hare)-poolsā¦! You simply canāt calculate like you do! The longer you are mining in the pool, the bigger your piece of cake! Pool hoppers who mine here for three hours and there for eight hours do not have this bonus (and rightly so).
Nice. Waiting for telegram annonce
Meanwhile lol has 1.41b with tonuniverse fixes
update is now in Hiveos
So youāre telling me i should mine for 3 years for free with little to no rewards ?
How long do you suggest i actually mine TON before i see any rewards on it ? a week a month a year ?
Lets be honest most crypto crashes/moon very fast by the time i get any rewards its probably gonna do full cycle of moon/crash (Implying it didnt already mooned since 23/12)
Im a small miner finding GPU in my country is next to impossible unless you pay 1K ⬠for 3060TI which is outrageous
Maybe thereās a reason ppl do the pool hopping
the profit /gh already plummetted in 48h it was 0.45 went to 0.37 ton because everybody who mined eth switched to ton cause of eth crash just like me
0% pool looks sketchy af tbh
Iāll give it a month even tho im very skeptical about it
If anyone has a better OC/Undervolt settings for the rx 6600 iāve managed to put them at :
1,621 gh/s 82w with a temp at 60 - 70°C
Getting this on every miner I try to run.
Anyone has any idea what happened here? and why I canāt use lol miner?
Any help would be amazing!
To be honest: You just didnāt understand the principle. I would suggest that you first inform yourself about the basics of mining before you are the only one to get upset here. Why do you think the miners are otherwise satisfied with it? Because we canāt all count to ten?
Learn the difference between PPS and PPLNS.
BTW, tonuniverse.com calculates with 0.5 TONs per GH:
Hi all,
Here is my configuration.
For Rx 6600 XT (sapphire).
I can push them to 2400 (core), but thats less stable.
With LolMiner
If you have ideas for managing consumption, donāt hesitate.
how did you put it working with lolminer? canāt seem to get it working
What pool would you recommend?
You must create a wallet (web wallet, for example), on the TonCoin website, then activate it on telegram.
Why advertise the lesser one then ?
Dropped to 0.36 now
So there was a reason for pool hopping like i said
Yeah sure its higher it also doesnt work through hiveos and yes i made the custom miner with the correct wallet/pool id through the bot & correct download & correct wallet
Edit : Even followed a youtube video 5mn of a turkish doing it live just to be sure i cant the see the problem rn
