The one with the higher profit / gh obv the more popular the less rewards
Famous cause :
tonpool default through hiveos doesnt work for many people
Tonuniverse has to be set manually
So yeah everydoby going to the easiest to setup that actually works and it shows on rewards apparently
Thanks @natsou_k, done that and when I have ton poll with ton-miner it works, when I try lolminer either with ton-pool or whales it exits.
Really strange
You’re welcome. What is the error?
And the log that presents the error in more detail? On the other screen.
I’m using ton-pool with ton-miner and it runs, if you find the answer please share, I’ll keep looking
Change the core to 2200 if you have a 6600 NON xt and its my setup
Thanks. But it still didn’t work…
Did you registered your wallet on telegram?
Yes. it works for me on danilaminer but not on lolminer
If you refresh the page you can see that the price jumps a lot - means that’s its current price and not some average in time, could be misleading unless someone mined there for few days? Still the day average should be around what we can see on minerstat.
ioiminuer v.1.41b works stable now a much better than v.1.39
As for people who don’t know much about mining and whine a lot, why bother ^^
Try hash rate.no
very useful
cheers
Config for tonuniverse that doesnt work tho i followed the steps & even the video still doesnt mine after confirmation from wallet & pool id on telegram by bot
You aren’t able to set up a correct flightsheet and blame who for it?! Funny, that’s not just me mining at tonuniverse.com since hours with high hashrates … and everything runs stable with lolMiner 1.41b
Later this day I will write a step-by-step instruction, just be patient and stop trolling here!
I blame the guy who made a guide for it saying to use a custom miner on their homepage obv
Before calling me a troll i set everything right using lolminer solved my problem which isnt what the guide says at all
So anyone figure out to exchange in the US yet?
