hi is this wallet safe to use
because i cant see withdraw option only deposit
You can’t see withdraw-option because you don’t have any TONs to withdraw :wink:
Me and many others are using it, too…
ok thanks
So do anyone have find a solution for the problem of the miner restarting all the time ?
Yes, there’s an ā€œemergency updateā€ of lolMiner 1.41a. Hope that Hiveon team will implement it soon.
Hello. Does anyone found a solution to withraw from the Ton wallet to Gate.io?
Gate.io insists that they don’t need the ā€œcommentā€ to receive the transfer.
By the way, to make swap using the bsc, it takes you a fix ammount of 5 Ton’s plus 25% of the ammount on fee bridge which is not so cheap (I tihink).
Thank you for your comments on this.
There is huge cap between pool hashrate through the bot and the actual hash rate im doing on hiveos im at 3.2gh/s but the bot says i’m at 0.45gh/s …
Ive been mining since 12h and its not updated nor accurate anyone has same issue ?
I’m mining in https://ton-pool.com/. I don’t seen any gab between hive report and bot one.
Im on whalestonpool because tonpool didnt worked at all yesterday will try and keep you updated
Hello how much i get when i found block?
Looking forward to an update mate. I had issues during the night, but as of this morning I’ve not had any issues with the pool.
I do, however, have a 3060 card I need to downclock to 170 core to not crash the miner. Not sure if that could be a reason for your experience of restarts.
After 1 hour i checked with the bot after switching from whalestonpool to tonpool
Hiveos reported 3.2gh/s
Effective hashrate 24h: 0.81 GH/s
Effective hashrate 1h: 0.38 GH/s
Effective hashrate 1h: 0 GH/s
So yeah still an issue :frowning:
Hi, you won’t find a block because solo mining isn’t possible yet…
You can’t trust these numbers anyway :wink: these are PPLNS- pools, no PPS! You have to mine fully 24 hours in order to compare each pool… not just one hour!
With my toncoinpool-rig the hashrate is same as my rig:
Same a few days ago with my whalestonpool-rig.
If the mining without solo then the best Eth from now. Or RVN
:man_shrugging: If you think so, okay
Clearly yes because this means mining for 12h i got 0.3€ with TON
Used to get 1.8€ for the same period & less Wattage on ETH
Clearly hashrate.no should update their rewards cause there is huge gap between what they say & reality
Why do ive such a huge gap your hashrate is globally the same mine’s is 3/4 less than its supposed to be …
