Thanks to gunzen and all that have contributed to this thread. I have everything setup short of turning my miners to mine TON. The reason I don’t turn them over is that I am in the US and I don’t see a clear way of converting TON to something else. Has anyone figured out what exchange(s) is/are viable for those of us in the US?
Hello guys,
I have a issue when mining TON, for some reason the miner is restarting all the time, like every 10/15min do some of you have the same issue and manage to patch it ?
Ty
same issues here. Seems to be a pool issues. Try all 3 server and did the same things except the first one. but this one crash every single day.
I cannot even connect to the first one, it made the miner crash and boot every time
There isn’t one. Gate.io address isn’t correct, same with Hotbit. Luckily I hadn’t mined to long before figuring this out.
I’ve signed for an account on FTX and I don’t see TON under wallet and deposit. Where do you see it?
Someone try TonPool ??
Use Okex.com you will get a real TON adress but you cant mine on it cause you have to add a coment on your deposit, so mine on a real ton adress adress and from there you can send on okex
Unfortunately, I am in the US, and Okex services are not available for those in the US.
well so yeah i can only advise you to mine ton on a real adress and then use the bridge BSC, cause eth bridge fee are absolutely insane
Same here. TONPOOL reboot after 15 minutes. So it seems to be a miner probleme. LOLminer sucks
I’m having the same problem with LOL 1.40, reboot after 10 minutes, then a moved back to 1.39, and went normal again.
I am not familiar with BSC, can you point me to a guide so I can learn about it?
TON-BSC Bridge you just need to input your BSC adress, you need a metamask, then you go on pancake swap and swap the ton for bnb and you send them on binance
What is your card and OC ?
4 x 3060 Ti = Core 200 / Mem -2000 / PL 110
2 x 3060 = Core 200 / Mem -2000 / PL 100
Have you tried setting the mem to 0? Seems it makes no difference, and did find some stability issues on a card when you underclock it too much
Just started mining Ton on 3070Tis Seems like ram can take a break after mining on ETH. Tried with 230w as well but got barely 0,1GH more per card so its not wort. Will try to play more with settings for those cards. Thx for the how/to! Only problem I had, was to use lolminer as ton miner had issues with working at all and had to send funds to hive to run 2nd rig outside of the 4x free on hivepool policy.
I thought I would test out a 6600xt on Danila-miner. I am only getting about 75-80% reported hashrate and coins from pool compared to what my rigs say they are outputting. I have 32GHs and pool reports 26GHs. Things seem more stable with lolminer 1.40 but I wanted to see what danila-miner did for me. On this 6600xt I am getting 1.6GHs where on lolminer I was getting 1.8GHs. Curious if anybody has good AMD settings. I tried what I found online, and the site said should get 1.9GHs with more aggressive overclock.
