That’s all you can see right there on the screenshot. Core 2400 VDD 610 MVDD 1200
Same for normal 6800
only difference
6800 PL 180 & 6800xt PL 200
@gunzen Thanks alot to initiate this thread and give useful information. This will be become alternative of ETH 2.0 issue. I have tried with all OC setting same with ethereum setting, and the result are fine, electricity are less. Just now we need compare the actual profitability. Thanks alot and keep sharing.
Anyone got decent settings for RX 570/580 with TON?
Hi
Anyone tried using 1660 Super?
This pool has some issues after 19-15h stopped working.i don’t know do you have such an experience.
Were you able to resolve your receive address problem at gate.io? I have the same problem, gate.io deposit address is not accepted by the Ton webwallet. It’s also 42 characters and wallet wants a 48 character address. I also tried hotbit and it also generates an Eth looking 42 letter address. Msg’d both supports but no response yet.
FTX works to recevie TON.
hi, thanks for your information
just a quick question, im mining ton on GPU 0, its originally a suprim x, which i have flashed to EVGA. Its getting pretty hot with that kind of OC setting. Any ideas?
Having some problem, can’t make mine to work. This is what my miner is displaying and I’m at the latest hiveos update
I see the worldwide problem with crypto these days
the bears
are in town… but keep on going, in a few days the bulls
will return!
So I keep getting restarts, do you think its a pool problem?
I’m running 3060ti and 3060’s at 200core 0 mem 140pl on Hive. Seems everyone uses these settings so I’m surprised the miner is crashing.
i changed miner, lolminer crashing constantly for amd and nvidia. ton miner is for now better
Help im trying to mine toncoin
Ive set up my ton wallet at : https://wallet.ton.org/
i’ve been accepted on the whale pool wallet by bot, sending my wallet adresse through telegram
I tried using lolminer & tonminer my 2x rx 6600 arnt mining i tried to update hiveos to latest version nothing is happening at all anyone has same issue ???
In shellinabox it says the miner is running i tried to reboot after update nothing :x
No working connection for 300 seconds (Authorization or Work missing). Reconnecting.
Ton pool connection mode: https job polling (ton-miner compatible) (–ton-mode 1)
In worker it says that when i used the command motd watch
I switched to the pool address above and it solved my problems.
what pool adresses did you used and using now ?
Not sure which I used, but I switched to pool.services.tonwhales. it’s been running over an hour now and before it would crash every 5 mins
Its purely the pool jesus … It worked for me thanks !
Yeah I was getting super frustrated too. Glad it worked for you!
