What is the DAG size? Can it be mined on 2GB or 4GB GPUs?
We dont have any dag size yet. But i heard somewhere on youtube that yes you can mine with 4GB GPU. I will try to retreive the info.
its not wallet problem , what your miner?
im sure if use lolminer U can get more just see here is my setting on windows
so ihave been mining TON for few days now with my rx 6800(3.5G) and rtx 3060(1.8G) and with my calculations im getting about 5.7 usd witch i could get 111mh for ethereum and make 6.27 from whattomine
Are U making more that eth right now?!
Hei iam new by TON Mining, i used the toncoinpool.io but there are no stats visible, does anyone know how long it will take until I see the stats?
how can i get LolMiner for Mining toncoin in windows?
Hi, I am currently mining ETH and I would like to select 4 LHR cards to mine TON however every time I run the new flight sheet with the extra config it seems like it’s only mining ETH and it doesn’t want to mine TON with lolminer.
Thanks for your help
These are my settings for 6800 & 6800xt
Full hashrate (?) for a lot of power.
I’m having the exact same issue. Don’t understand why didn’t work
Do you have device numbers in extra config for every miner?
just download lolminer from this https://github.com/Lolliedieb/lolMiner-releases/releases and stup wallet and join a pool just like ethereum or others
Ok so you are running 2182 clock and 140W to get 3500 MHs. That is about right for 6800. It looks like 200 MHs for every 100 Mhz core clock.
For my 6800XT at 2000 clock and 150W I get 3700 MHs, so ~2200 clock is probably 4100 MHs.
this is my current settings, using latest lolminer.
can u post ur 6800xt oc settings?
thank you
I have two gigabyte cards with Samsung RAM … they don’t overclock that much without crashing :wink:
Hey, I just made an actual comparison between ETH and TON profitability and the TONCOIN is still on top! (Test-Rig: 1x 3070, 9x 3060Ti, 1x 2070 & 1x 1060)
Read here and install…
yes, hope better stability.
what pool are you using ? i’m currently on whalestonpool.com
to high ping at toncoinpool.io 200-800ms, at first 30-50
Much better performance! :+1: I’m on Whales, too (pool.services.tonwhales.com). 34 ms :slight_smile:
