I looking for best settings for ETH+TON dualmining with 3070Ti.
Anyone have an idea?
it works now, thanks alot !!!
i, dual mining on 5700 nad getting 55mh on eth and 3.3gh on ton but i have notes that the ton mining part is not getting any shares any one here checked that?! it just emty hashrates and no pool shares
I had the same issue. It is the power.
I would increase the power limit to 140w at a minimum of 3060ti. I am seeing the best efficiency on mine around 145-150w. Cheers!
dunno, why cant i change Second hash algo to TONDUAL
i have only zil and ETC
i`m mining ton alredy, but solo.
any help why cant i change it on hive ?
You have to use Lolminer 1.43. This is miner with dual ETH and TON for now.
I got it, but i`m stuck on making dual mining flightsheet
cant choose TONDUAL
only ETC and ZIL
This is what worked for me:
After trying the initial settings and couldnât see it, I refreshed my browserâs hiveos webpage on the flight sheet and selected everything from scratch. When I entered the âSetup Miner Configâ section after selecting âlolMinerâ, I could then all of a sudden select âTONDUALâ below the âSecond hash algorithmâ and select version 1.43.
No idea why only after refreshing my webpage on the flight sheet of hiveos that it displayed these settings after initially trying to add it the first round. Hopes this helps. It worked for me.
wOw!
WORKED!!!
Awesome.
Think itâs another hiveos glitch on some accounts.
hi did U check your hasrate at the pool is it the same i found that im not getting enough hasrate at the pool like i have 3.8gh but it only shows 0.7gh i guess dual mining is not working that much!
Mines right on the pool side with a small variance.
Located in US and getting alot of rejected shares on ton whalesâŚanyone have a better pool?
Tonwhales has lots of issues, especially with lolminer. To use toncoinpool.io under dualpool select âconfigure in minerâ then input the following in the lolminer 1.43 config:
Algo2 TONDUAL
Template2 %WAL%.%WORKER_NAME%
Server2 wss://pplns.toncoinpool.io/stratum
yeah changed it and now it works fine tnq man
Anyone tried mining TON with a VEGA 56/64 card? I tried last night to set up dual mining on my rig. Well my Vega cards dropped in Hashrate frome 56.4 to 49 MH/s but they donât mine TON at all.
Anyone with a Vega56/64 to try it out?
i have tried with my vega 64 that i bioses to vega56 well it gaves 2.2gh on ton and 40mh on eth but i found thath im not fining any shares on Ton side also i had hard time crashing to set it up this vega cards are too hard to change XD
