Can you detail how you setup your flightsheet?
I tried making the flight sheet and it failed to create, failed algo2…
Then click “setpup miner config”
and add these arguments:
Here a link to the manual
Thanks!
any idea why my ton hashrates are so low?
It all about your core
have you check this page
And check here . for some examples. for the 6800 they advice 1800 core clock
Ow and after you change core. don’t forget to restart the miner.
I think lolminer has to do some load balancing between the 2 algo’s
I just thought it was odd that the same cards with the same settings were jacked.
and the 6900xt looks completely wrong.
Hi, first I want to thank you for your support :+1: Good job!
Second, I have exactly the same flight sheet for two of my rigs. One consists of 5x 3060 Ti LHR and Two consists of 4x 3060Ti LHR plus 1x 3070 non-LHR.
My problem is that number One runs pretty fine, but not number Two… look here in the summary
Here is number One in detail running awesome good:
And here is number Two… and now tell me please - where is the fu…ing problem, that just the non-LHR and one LHR card (which is out of the same bunch as rig One) are mining TON:
I don’t know any further… :thinking: :expressionless:
Thanks! no problem. Only mine 3070ti is a LHR, all other are nonLHR.
About you issue.
  • Maybe it is something with the memory clock. Start on 2000 and see if this is working. if this helps you can later increase memory
  • Swap some card in the rig…see if this helps
  • total shutdown & boot in 30 seconds?
Hi help my please .Not startin dual mining.
Sorry I don’t see any fault in your flightsheet.
Maybe post in TON telegram group Telegram: Contact @whalespool. The Lolminer developer is also in this group. Maybe he can help
Leave the pl empoty.
Same here, only mine Eth
They also add an short description how you can configure here . Slightly different than I did
did you manege to solve your problem? When I start my miner i always get dag verification error. It automatically starts with repair and after that is works OK, but it is strange
Hi.
Same for me, the setting is very sensitive and the cards heat up quickly. (Rx6600XT).
I did not manage to stabilize the whole, even with the values ​​recommended by Lolminer (the consumption, per card, reached 140w). As far as I’m concerned, I’m waiting for future updates or to have a little perspective by consulting the forums :slight_smile:
can you show us your configuration?
Put your wallet adress and not the name of your wallet.
Like that :
