At least it is working. I tried last night but I wouldn’t start mining TON. I was getting the info n/a only.
im sure there is a way to this and im sure it is easier to do it on windows!! but i dont have accesses to my vega right now! im may be do it later
And I tried to run vega 56 out of 8 cards start only three and reboot
Pooling to Ton whales? Could be. I haven’t seen that in mine, but I may have crossed over prior to that.
hope it be fixed by lolminer
hello,
my rig keep restarting in lolminer 1.43 tonwhales pool i changed to tonpool
still the same problem
i find there is problem with version 1.43 lolminer with tonwhales pool and there is problem with tonpool keep restarting after updating to 1.44
i will try tonwhales pool after update
i am looking for trusted stable low fees pool
any one try these pools tonuniverse , toncoinpool , icemining ?
this my oc
Not sure for how long the Dual TON mining will remain profitable as the pools increase in size, the payouts are not that sexy anymore. This is a stable (running for 48 hours) setting for one my rigs. I will post more as it goes. thanks @Xmax for the Sapphire OC, which happens to work fine for the PowerColor (at this for this small rig).
Just a small reminder for those trying to work a dual setting ETH+TON using TRM - it will take double of the time to for the miner to find its setting and if you change the OC, then a reboot will be necessary again. So be patient.
Guys I need a bit of help. the Memory temps are getting too high (at least for me I have been running them below 60 degrees) … I have decreased the core OC (actually I can OC the core with 1800 and have about 1400 GHs each, but it will pull about 90-95watts and I don’t have amps left to risk it). Would appreciate some thoughts how to deal with temp - running other rigs with the same GPUs in the same room, same TRM, Same Mobo and 1800 core OC no issues with temps…
Hi, do you use lolminer? and witch version?
sorry for the answer in 2 time.
I spent a lot of time on my rigs to manage these temperature increases.
But I use LolMiner and I have the impression (when I see your print screen), that you are using another miner which does not handle double mining in the same way.
As you can see on my screenshot, with a higher core than you (and LolMiner) I get a lower hashrate on TonCoin but higher on Eth.
When I go up to 1800/1900 (core), my gpu overheat and my rig ends up crashing.
The solution is to decrease the core, restart the rig and do it until the overheating is “under control” (For me, some cards support 1750 core others 1550). This takes a lote of time.
But I’m like you, I prefer to limit my hashrate and preserve my cards with core temperatures of 50/55 max and mem of 60/63 max.
(can you pleas post your fight sheet config please?)
Hello everyone, I read a lot of people who said that Ton mining was temporary, do you have any information on this?
probably as more people do it, it will be less attractive. Dual mining with ton will be worth it, until the results stop being interesting to you.
Also, could be that ton will go down the drain. It is hardly listed on any exchanges, the volume is small, and it is a rather newcomer so not matured. At least now it is listed on 6 pools. Hope it flourishes
It is kind of free mining (except for a bit more energy), but would hate wasting effort. Maybe not if you aren’t hodling.
Thanks I can see you opted for higher power usage benefitting the lower temps. Nice job! I am on the limit of the AMPs and I cannot allow more power to be used. I am trying to solve this, but will take time…
I use TRM (Team Red). I like the results and the low power use. I tried lolminer, but somewhat it didn’t work for me, perhaps a matter of preference for the TRM.
Thanks for the print screen
do not hesitate to share the result of your configuration, it is always very interesting.
For the extra config arguments, i m on toopool and i dont know what change. Is it something like stratum+tcp://next.ton-pool.com ?
Thanks again
Ben.
When You increase the core clock Ton hasrate goes up but power consumption, too. This is my setting. As I don’t have good cooling, I don’t increase so much.
may ask why i cant see my stats in the pool
