I just use the mobile app respective my favourite links in Chrome⦠so for me seems everything to be fine. But I have tested your link and youāre right
Source?
Inside the original OKEx- app there arenāt any messages pointing to this massive changeā¦
Is anyone tried to send toncoins from OKEx to wallet?
When iām trying the withdraw form shows me āIncorrect withdraw addressā, but the address is working ⦠whales-ton sends there my tons from pool.
For 6800xt you can improve to 4.5 GH/s by clock 2400 VDD 610 MVDD 1250 PL 220
Now itās official: OKEx isnāt been hacked they branded the firm new in OKX. Everything is alright!
Hy,
I find that I have a big difference between my hashrate and the hashrate shared on the pool after 72 hours. Iām at 8G but only 7.2G on the pool
I use argument : --cclk 810 --mclk 2100
200 / -1500
3080 ti : 5G
3070 ti : 3G
Men you need to hide your IP and your MAC Address come go on delete the photo and try messing a bit with your IP to change it if possibleā¦
Has anyone had any success solo mining? The gambler in me wants to give it a shot
Itās easy. I use FTX. Convert TON to USD and the in my case i send BUSD to Binance without fee⦠But u can convert to USDT and others USD cryptocurrenciesā¦
It depends how much GH/s do u haveā¦
Thanks for the tip. For now, I decided to hang on to my TON and see what happens in the next few months.
Iāve got 14Gh. I know you need a really strong internet connection since youāll be connecting to different āgiversā (pool does that when you mine in the pool). Did anyone try solo?
Anyone tried toncoin.plus pool with their miner?
Anyone dual mining ton & eth? Cheers
