You are welcome!
Hi guys
I have 11.66 GH/s on my Hiveos but when i request for my balance on Telegram robot i have 10 GH/s . What is this difference for?
1% development fees for lolminer i think.
Its the last 24h hash rate right? And it cumulative of real hash rate that doesn’t mean the same as in miner. Also if the miner was offline for some time than the hash rate will be lower there as well.
On which pool?
Tested cards 6700XT, 6800, multiple 3060Ti_LHR.
Hello there best settings I could find are here:
Miner : lolMiner-v1.42
6700XT
Hashrate 2.30 GH/s
Power 84 W
Clocks
core, memory, core UV, MVDD, MVDDCI
2300,1000,875,1300,800
2200,900,875,1300,800
6800
Hashrate 3.65 GH/s
Power 146 W
Clocks
2300, 1000, 875, 1300, 800
3060Ti_LHR
Hashrate 2.29 GH/s
Power 99-114 W
Clocks
core, memory, power limit
300, 810, 115
300, 0, 115
300, 810, 125
300, 810, 105
@gunzen
Ftx and okex use tonnetwork or eth?
Gate.io only uses eth/etc 20
Tonnetwork
Can you stake? You have both of them?
i get less accepted shares on tonuniverse than on whals pool… where could be the problem?
my rx 6800 is pulling 216w with this settings…how do you get 146w?
Can you share the configuration for your vga 6900xt and 6800xt for my reference?
This is my configuration about RX 6800 XT and I think I can lower the electricity consumption :wink:
Got 2 question:
  1. Why command /balance dont show profit toncoin per hour/day ? Show me only
Your pool balance is: 0.9890831 TON
Effective hashrate 24h: 24.8 GH/s
Effective hashrate 1h: 23.59 GH/s
  1. Mining is still profitable ? Becouse on tonwhales now is low Profit per GH - 0.2894
yes, it goes down but it is better than the other coins !!
I have the feeling that my mining profit does not match what is presented on their website. So I’m curious which mining pool you use
Which mining pool do you use?
  • TON Whales
  • Toncoin Pool
  • TON Universe
0 voters
This is how i set my Rig’s. Maybe it can help somebody or give some new idea’s
As an addition I lock the mem & core in the flightsheet with these arguments
Missing some hash on that 3070ti
I know that the ti can do 3.1 gh. But is it worth the extra 50 watts that it needs? For me it isn’t. They (3060ti,3070,3070ti)all use the same chip, but with a different cuda cores. My rtx 3070 can also do 2.9/3.0 gh at 185 watts (lock core clock @2100)
So what the best setting for those cards? MIne with cclk 810 and mclk 2100 several time got crashed, with notif “unrecoverable memory error”
