some overclocks have been stable over 24hrs now
memory -2000 core 250 try that ton does not use memory like eth
me too.
They do not give the right figures
try slightly lower core
just stopped working ton universe.
is anyone sure that website is legit? first they increased the payouts to 3ton then their balance stops working even thought shares keep being found, anyone knows?
Now the threshold is 5 TON
hey man just get a good vpn like proton and use okex and do usdt to xlm and get your coins to your coinbase hella cheap . good luch
Hi dear friend
i have 6700 XT too , but when i set to your OC the 6700 GPU goes down.
my current setting is :
I think we have to stay efficient.
With the fall of the last few days, it’s less sexy to mine TonCoin, but it’s still more interesting than eth.
I dedicate 9 Rx6600 xt on TonCoin and I still have 18 Rx6600 xt on eth (which allows me to compare.)
And here are the results.
with Lolminer and TonPool.
9Rx 6600 Xt generate 6.38 TonCoin / Day
Either: (without the electric cost because, it is true, TonCoin increases the necessary power.)
at today’s price: $ 17.42
at the average price $ 21.7
at the high price: 28.7 $
And for the eth
at the price of the day: $ 13
at average price: $ 16.4
at the high price: $ 19
Let’s not forget that the eth was at 700 euros 13 month ago.
If we look then, today, TonCoin is more profitable.
Have a good day
Ben
Does anyone use Gate.io to collect their TonCoin?
I would like to make a transfer but the wallet that Gate.io gives me is not 48 characters long.
Thanks in advance
Ben.
this OC you use good for Ethash algo not SHA256-TON
leave memory clock as it is (blank) , remove all undervolting then put core clock 2000 then little by little go up and find stable core clock for you GPU, after that you can play with VDD and VDDCI for undervolting
same for me , tonuniverse is scamming people with fakes profit/ghs
Hello @natsou_k they have gate.io in ETH network, you will not be able to transfer directly there. for now I’m holding to them on the ton wallet.
Hey GPU-Heads
I would like to take up the problem with the tonuniverse pool again: we certainly agree that this pool seems to have extreme problems. In the last 48 hours alone, the withdrawal limit has been changed four times, the backend was faulty, the mining protocol was switched from PPS to PPLNS and back to PPS … all in all, a very unsatisfactory situation!
BUT: we should be careful with terms like SCAM …!
I don’t want to protect anyone here or take sides with any side, but none of us knows exactly what’s behind it! Whether the operators of the pool are just a few script kiddies who want to make a quick profit, or whether they are two hard-working guys who are trying to get a new pool on their feet in addition to their “normal” lives and have to deal with any problems permanently without a large team behind them … we don’t know!
And that’s why I would like to ask you to refrain from making such accusations in this thread, thank you!
Hi gunzen and thanks.
Do you know if this param (lolminer) :
–mclk 810 --cclk 1740
Can be use with rx6600 xt?
Ben.
