My 6800 xt starts with setted value. I can screen you if you want
If you wouldn’t mind, would be great. Here are my card settings as shown in amd-info once booted. Note, I tried leaving the core clock speed at default (0) to see if it made any difference (it hasn’t):
Hive settings:
is anyone dual mining eth + ton coin ?
Yes, I thinking, rx6800xt/6900xt are the best card on the market for dual mining eth-ton. My config 6800XT: 62MHS eth/2,6ghs ton 150W RX6900 62MHs eth/3,2GHs ton 165W Can make more, but than the power consumption will be higher
Can you Share the OC settings please?
rx 6900xt: 1700/710/785/1285/1060 socvddmax: 860
rx 6800xt: 1600/695/765/1285/1061 socvddmax: 860
I hope this help!
Thx!! PLEASE CONFIRM.
Socvddmax Help!
AMD 6800
- -Core Clock, 1600
- -Core Voltage, 695
- -Memory Controller Voltage, 765
- -Memory Clock, 1061
- -Memory Voltage, 1285
i
Yes that’s ok
thx!!
Just a tip, remember when you read 150w, it’s actually way more
“only” 50-60w per GPU difference between software and the wall
AMD software power usage reporting is A JOKE
Thank you btw, should be checked the new profitability as well
670watts whole system. I think 50-70watts for MB/CPU/ssd/memory and other. So 25-30watts per GPU is OK. IMHO everything that goes through riser isnt count by drivers/software.
Usually hardware out of gpus pull up to 30w maximum 40, which means the remaining 630w come from gpus, which mean an average of 210w per gpu, this is 30-40w MORE than software reported.
Man this is INSANE, and stupid af.
Amd should include riser current as well, they just calculate in completely different way the current used by the gpu from nvidia
(make me mad af)
Core voltage is not applied, you need after reboot to wait for miner to start working, then apply core voltage. If you set on 700, after reboot it won’t apply to 700mv, it will take as much as it wants. Change while rig is working after like 2-3 minutes to 699 then change back to 700, and power draw will go down.
10 Powercolor Fighters 1950w from wall.
SOC 900
SOC max 900
Good morning,
I have a question about the SOC TDC Limit.
How much do you think is safe to increase thie value?
How suggested in TeamRedMiner guide i have increase the default value of 30A to 33A becsuse i was limited in the hash rate.
Now, looking whit HwInfo, while mining the GPU SOC TDC Limit is an other time at 100% and I think this cap my hash rate.
Someone has suggestions?
Thank you.
Dated information depending on which Hive Kernel you are running on. Kernel information is different than the HiveOS version.
You’ll want to provide the kernel(#xx) and OS version shown at the lower right corner of your HiveOS.farm web interface so folks can share some guidance.
And if you want a quick answer, overclocking and AMD-info from a shell would expedite.
I have this GPU Radeon RX 6700 XT 12272 MB · Gigabyte Micron GDDR6 · 113-D51210-X67XTGO
What are the best OC settings for such cards in your opinion
