First thing first, welcome here.
Samsung memory are known to be more sensible to high clock, indeed, you have many at 900 which is the “common” limit of samsung.
Here my setup, it’s a different brand/model so i don’t know if my OC works for you, but in this way you can lower your power consumption as well.
Moreover i also use the --eth_config parameter into the TeamRedMiner extra config, in particular this:
--eth_config=B640 basically this fix the GPU Tuning allowing TRM to skip this step.
The B mode is known to lower the power consumption, maybe this can help you a little bit with your rig in general
can you share your memtweak?)
