Can you please share your settings for this mate. Love the temperatures you are running. Cheers!
Hi guys, me again.
i need opinions on this OC config because i have many errors like “GPU XXX Dead” and i cant obtain a stable rig. sometimes is like 30 minutes or 2 hours without problems but at the end always one gpu dead (i suppose is the OC)
ps: all gpu have BiosMod, in TRM i put the argumments "eth_config=B and “eth_big_mode_adjust=64”, i checked and swap all riser.
Hi Guys, Can Anyone send me an Link to Flashed Bios Files for my 2x 5700 XT
Because i dont come Higher than around 50 MH/s with each Card.
1 Times its the XFX 5700 XT Ultra Thicc II
1 Times its the Powercolor 5700 XT Red Devil
Thanks for Help
u should go for ur 3090
Core 1200
Mem 2650
PL 420
that will be good for ur card and its will be last longer
hi,
would be very grateful if you can share your bios mod 5700 XT Sapphire Samsung GDDR6 · 113-D1990103-O09
I do not rise more than 55.3
[email protected]
hi,
[email protected]
I also have 2 5700 XT Cards ,and i failed to flash their bios with RedEditor on windows portable , because im using Macbook …PLEASE if anyone can send me any flashed bios for :
Asus Tuf 3 RX 5700 XT Micron
Sapphire Nitro+ RX 5700 XT Micron
I wish everyone a great Year
What is your SoC settings?
It is normal that all my 5700xt dropped about 0,5MH/s each comparing to MH value that was in September ? All my 5600XT have stable MH with 0,01MH accuracy from begining. Nothing was changed in rig, hiveos, OC etc.
Sure, what ASUS do you have? These are ASUS 5700XT Dual EVO I’ve emailed the modified bios i used.
I have the strix model. Do you find you have issues beyond version 0.6-203 on HiveOS or do you run the latest??
I see I don’t have bios for that model; if you like send me your original BIOS and I can create them for you. I’m running .6-203.
I was running .6-203 but recently updated and no issues
If you want I can mod your original bios for you, just send it to my email. You should have received them from me when I emailed you the previous bios.
Does anyone got updated VBIOS for 5700 XT Samsung GDDR6 113-230LNAVIXT612_8GD6_MS_W8 on HiveOS? I can’t get over 51-52MH on stock BIOS and would like to push it over 55. Thx!
send me your bios, i’ll mod it for you
Thank you! Already got the moded VBIOS from another member. It’s running strong at 55.7Mh (was 51.5Mh) using only 2-3w more.
Now I’m looking to see if there is a way to do the same for a bunch of RX 6600 and RX 6600 that I’ve got.
I have 6x Powercolor RX 5700 XT (AXRX 5700 XT 8GBD6-3DH) with Samsung memory. I moded their BIOS but i can’t push them more than 900MHz, there are 2 of them that i can not push more than 885-890MHz, reaching 54MH/s. If I put them with 900 i got GPU DEAD error. (i am in process to low voltages, so do not pay attention to them, usually i’m working with default memory voltage).
What do you think? am I in the maximun of this cards?
