MEM - 800-900. You have 1840.
Did you prepare mining bios ? I have Sapphire RX 5700 XT Pulse 8GB Micron, still usually only 53mhs, Do you can help me ? Thanks in advance [email protected]
Can you Please send it to me bios mod for Radeon RX 5700 XT 8176 MB · Gigabyte Micron GDDR6 · xxx-xxx-xxx
Modèle : VGA Bios Collection: Gigabyte RX 5700 XT 8 GB | TechPowerUp
a big thank you for your help
I sent you an email. I hope it’s still relevant
Hi i bought new one MSI Rx 5700 XT MECH OC .
Terrible guys . i changed bios of these :
113-MSITV381MH.101
113-MSITV381MH.102
113-MSITV381MH.103
113-MSITV381MH.112
But with OC
1420
800
920
1350
And no way to goes up over 52 MH . So any advice?
hi
You can download correct bios for your card here or download your nitro xt bios in hive cards tab to your pc and do the timings (& tREF) mod your self.
I have sapphire pulse mod bios that work with nitro as well but anyways i dont want to risk that u end up having issues with that mod. Good luck
Hi, do you only use timings and tREF or use MPT too?
Which are the tREF values you are using?
Thx!
hi guys, any recomendation for Asus Tuf 3 5700 XT ? high temps mems…
timimings and tREF x3. I did change some with MPT…min GFX / SOC to 700mV… Max gpu power down a bit…sorry, cant remember now for sure my MPT settings
Thanks!
Any tips to get the asus strix rx5700 watt down? I can seem to put it to 928 memory pretty stable. I found power limiting it seems to be the most stable but its on the higher end of 120-130w. Wondering if anyone else has similar experience or if the strix cards are just a bit more power hungry?
Still fighting with those 3x5700XT power color. No matter of OC (or BIOS version) it still gives DEAD GPU for each randomly (sometimes it can works couple hours, sometimes 1-2days)…Mem temp 70-74 so no throttling, autofan is OFF.
Any one have simillar experience with 5700XT ?
I would like to downgrade hiveos to 0.6-193@210118 (first with TRM 0.8), could someone tell where I can find this old image ? Hiveos gives only those versions Hive OS Images Historical Releases
P.S. I found also that it can be related to socMHz, TRM shows 950, should I make it locked in OC ? it is safe ?
Thanks!
Use Teamerdminer if not using yet
FAN to 70%
CORE start with 1300
delete DPM for this GPU
delete PL
hi, i have Sapphire Nitro+ Special Edition RX5700XT 11293-05-40G
micron memory
can you send me moded bios? thanks.
[email protected]
