Has anyone tried TeamBlackMiner on their 5700s?
is this graphic card is good for mining?
Anyone using this card??
Hey anyone have a asus arorus 5700XT samsung memory BIOS mod would be amazing. I have tried everything and its the one card I can never Mod.
[email protected]
能给提供在这个bios文件吗
anyone know what thermopads is in use in 5700XT Red Devil ? I would to change in one GPU because it’s sticks out of two identicals ones
Hi ! Have you managed to find a solution since time?
Please bro, what values are 1 5 1 and 0 ?
Settings have changed, those are dpm and mpdm which really don’t apply to the card. As it will independatly choose those numbers regardless of what I set. I am running a deshrouded with case fans on at the moment. Hence the 0% fan speed as well fyi.
Also used stock bios and only modified 1750 strap as advised by Bitby.
Sitting at about 95% accepted share rate. I’ve gone through this entire thread and others to find different settings that work. Even when I’m down about 53mh with other settings I still get invalids. Can anybody tell me what I’m doing wrong? I’m thinking I need to tweak the bios or mpt more?
PowerColor AXRX with 1500/1550 straps bios mod, nothing more.
hello hello, I have a question, is it compulsory to flash the bios (I have an rx 5700 xt) under hiveos?
thank you
Can you send me modded bios for 5700 xt Power Color. Most I am getting is 51MH
can you share your OC settings and any BIO mods you are using? I cant get more than 51MH with my 5700 xt PowerColor. Thank you in advance
Hello to all!
I’m just starting with hiveos and I need your help to optimize my rig.
Can you send me your OCs but also your modded bios (except for my 5700XT UO4).
A big thank you to you all!
Enjoy
Replace the heat sink patch and add more
try to raise core voltage to 800 to test. seems a little low for 1300 mhz for me
i do it thanks !!
hi there, Newbie here, how do i upload the mpt file?
is the same way has the rom file?
