Hello
Use Team Red Miner … with settings core 1350 / 780 and memory volt 800 /1310 with max for samsung 890 -900 mhz…
Use B mode on team red miner
Strange thing happened here.
I was running TRM with 1290 Core, 700 VDDC, 745 VDDCI, 900 MemClock, 1285 VDDM, getting 54,4MH/s at 85W. Stable for days. Autofans regularly going 75%.
Then I cleaned my GPU and changed thermal pads. It was very dirty.
Now this overclock is not holding steady anymore, even though the fans rarely need to go past 60%.
I had to increase everything a bit except for MemClock to get it stable…
Hi, please upload bios
i have red devil micron x 2
has anyone flashed a 5700 bios on 5700xt? does it work? less power?
I got an AsRock Challenger that needs a bios update and was considering using the 5700 bios instead of the XT version. Looks like it basically the same except lower power limit and target temp.
igotek, I ask you to share with me the BIOS for, bios for your XFX RX 5700 XT micron, if possible send me to [email protected]
Hey guys,
I’ve managed to bios mod (1550 straps) all of my 5700 XT cards which gave me around an extra 3-4 Mhs per card. (thanks to Igor’s Lab)
It seems if I go higher on the memory even with +5 the cards just start crashing randomly. It is stable at its current state but Is there a way to squeeze a little bit more out of them
i have read that 5700 bios might give u lower consumption, didnt tried tho…interesting, please let us know how it turns out if ur going for it
These are the settings for the 2 Powercolor Red Dragon cards I have (RX 5700 and RX 5700XT):
I use TeamRedMiner v0.8.5
AMD Driver 20.40 (5.11.0701)
Is it possible to mod RX5700xt with Samsung memory? After trying not only the card would not POST but the comp would not start. I had to used a different computer to get it back to stack BIOS.
Any advice is appreciated.
Brand of card ?
Asus ROG Strix
This card has locked bios …u need unlocked one…
thanks
I have small problem with two Powercolor 5700XT Red Devil. I get BITBY moded bios but GPU don’t work as should (in my opinion). Sometimes it can crash after half day (first or second GPU) … voltage 800/800/1350 is not helping. PSU is OK, risers are OK, the same with GPUs into moderboard…
Someone is using this model and can share own bios or OC with this GPUs?
I have the same cards, please try my settings (scroll up a bit, you’ll see it). Also, I noticed that your DPM is not set. I have mine at 5.
Do note that I modded my own BIOS; using the straps method.
You have samsung memory, I have micron&samsung mix
Dear mate, I sent an email to your mailbox. Hope you can help me to tune my Sapphire Nitro+ 5700 XT. Thanks.
Fix your core at 1375 at least for this mh/s… and vdd at 780 …
Added a MSI 5700XT two days ago and it has been so unstable and crash the whole rig, can someone help?
Put mem at 890… and remove PL…
