with 910 mem and stock bios you can do 52-53 mh/s at the best… set VDDCI 850 MVDD 1310 fan 80 and mem 910… and check…
Happy to help!!!
i have spoken too soon lol temp increase to 92 …
i think my old parameter was the best i can have zith stock firmware
wait 10 minutes…
ok will wait and check tank you for you help
hi are have idea or any link for my xfx rx5700xt ?
im in stock bios and dont like to mod bios
just need lower power usage with 50 or 52 mgh
thank you sir
HI,
For stock bios (universal safe settings is ) 1400core with 800vdd mem 890~900 with this OC u have 51~52mh/s… if you have high power lower your core 1350 with 750vdd…
If u have any problem post here… Always stop miner to do OC and then start it…
Have a nice day
Hi igotek! I’ve just read this. Do you have the baio for an XFX RX 5700 TX Micron GDDR6 · 113-180W2NAVI10XT8GD6_MS_191122_W8 ???
I cant get past 52 mh/s.
If you do, please send it to [email protected]
Thanks for helping with this kind of things, I’ve been reading the comments, its great to see people helping each other.
Hello.Do you have any bios for Sapphire 5700xt pulse with Samsung Memory?
I would really appreciate it.
hi igotek
please send to me professional bios for xfx rx5700 xt thicc III ultra and sapphire rx5700xt pulse be
my hashrate now is 55mhs 99w
my email: [email protected]
best regard
Do you think that it would work with my cards?
Thank you for your time.
first of all let me suggest to try TRM which now allows since 0.8 much lower core clocks AND core voltage. Im down to 1220 mhz at the same mhash than I had before with 1350 mhz…1220 allowed me to also reduce core voltage by 50 mV. saves a lot of energy.
next thing I found is an option. by default linux doesnt allocate 256 mb of memory / vram for safety reasons. If you havent connected a display to the cards, you can lower this value and let the miner allocate more vram. gives some mhash for free. this command option might be available in other miners too, for TRM its
–eth_big_mode_adjust=64
e.g. 64 is the lowest possible value. 256 is the default value if this option is not set. 128 gave me 0,5 mhash, 64 gave me 1 mhash for a 4 x 5700 gpu rig overall.
If you are not mining in bigmode for some reasons by default, try to force this mode with this comand:
–eth_config=B
pls report your results
pls use much lower core clock for trm 0.8+
you will see you can lower by 100 mhz at same hashrate…
omg…dont you all read the changelogs from miners you use? dont you ask why all cards have the exact same hashrate? why dont use 1600 mhz core clock? because its useless…as 1300+ now is useless too…since trm 0.8
suggestion for improvement? decrease core clock until you loose some mhash, than find your core clock spot where you start loosing…thats the max possible and max needed core clock for your actual mem clock!
that waste of power
Under win or hive os are -eth_config ?
