hi, if i dump the orignal bios and send it to you , can you modify it ? i have this hashrate with your settings but temp is overkill
Beware of revision 2 ā¦is locked bios⦠You need an unlocked oneā¦
thanks, how can i check if rev 1 or 2 ?
You see it on the boxā¦
ok i checked and mine is REV1.0
ok⦠you can modified with Red bios editor ā¦
i donāt know how to do this ⦠
disclaimer make me afraid
definitely not able to do this
i dont want to send you a bios because i dont have the responsibility for anything wrongā¦
Read and search ā¦
appreciate your opinion and help
thank you for the link
what can i expect if i follow the tutorial ? 59mh/s ?
With stock bios for Giagabyte oc micron mems⦠Core 1400 vdd 800 memory 900⦠nothing else⦠this is the best settings you can set⦠for lowering mem tempsā¦
Temps for micron ( ~76 celc ---- ~96 celc) you dont have any problemā¦
ok i will let like this⦠thanks
56 mh/s with temp 80ā¦
Yes, check it for 10 minitesā¦before apply settings close your miner ,and after start your minerā¦
letās go thanks for your answers
If you have problems with your temps⦠VDDCI 850 MVDD 1310 BEWARE FOR 900 MEM⦠dont change any value of this⦠vddci with mvdd values is only for mem at 900
Put your fan 80%
