Please help me for profesional bios mod
Hello, can someone help me with my Aorus 5700 XT itās running at high memory temperature and draining to much watts, at least comparing it to my other 5700 Xt Red Devil.
Both of them have modded Bios, used 1550/1550 timings to the higher Mhz.
The Red devil also crash if memorie clock set above 900mhz
For me, your command is not working. Itās putting the miner in a kind of pause mode.
Hii igotek . i saw your post on hiveos forum. İ have 2 gigabyte aorus 5700xt and 1 msi 5700xt mech.
Can you help me about make a Professional mod bios?
İ am sending you 2 gpuās stock bios . if your help me i will be happy.
Thankx for everything .
Hi
I have 4 pcs xfx rx5700 xt thicc III ultra
My hashrate is 54mhs
Any freinds have better and stable bios fir this card ?
If have please give me
Best regard
How did you do it ?)
I have a maximum of 51 with these parameters
You must modify your bios⦠(copy straps from 1550mhz to the above values )ā¦
thx )
Anyone here actually tried to follow these instructions to bios mod the 5700xt?
Thereās a lot more than just copy straps from 1500/1550 to the above values. What kind of improvement can we expect after following this guide?
I think here and so many have achieved 57-58mh, and with this instruction, stability and durability will improve.
Decided to increase the voltage at VDDC
its not work
my card is xfx thic iii ultra with samsung memory
but i test every config in this page via moded bios and card hanged
do you have any idea
check trm readme, maybe its a typo, or you didnt use the command correct. if you start the miner it shows the amount of memory you use, there you can see if the command worked of if its ignored
i used this setting but Hash rate is still 55.4?
what should i do?
Thanks for your answer. It seems now that it works. It was maybe typo.
I already put config B in the flightsheet but with āeth_big_mode_adjust=64 I have also almost 1,5mh/s more for 5 rx 5700 xt.
I stiill have problem with one GPU. Most of the time, itās detected dead and I still donāt know why.
I did everything correct about the straps and tRef but this GPU can be detected dead after 3 min or 2 hours. Still not able to fix this. I was wondering that putting some command in flightsheet would help me out but no. Even when I put this GPU in A mode, heās detected dead after few minutes or hours.
I changed OC but still same problem.
When I received that card, it was not possible to get picture from it. Maybe itās a DOA card ?
HI
Do you have bios moded for XFX RX 5700 XT THICC III ULTRA (Samsung Memory)
Email : [email protected]
