Those are brand new?
So so, they have a few months…
Nah why it show fix numbers? Pl= power limit I know… I would set power limit let say 120…but still:
PL 100w, 240w, 270w what is that…
I don’t know what you mean
he is talking about that
Thats what Hive considers low, mid and max power limits for that particular GPU.
there you have it !
Ben direk bu ayarları denedim. Sistem açılır açılmaz hata verdi.
Daha önce mem. 2600 power 125 62 mh ile kazıyordu. Şimdi 2000 mem üzerine çıktığım zaman sistem direkt hatayla başlıyor. Az önce formatta attım fakat değişen bir şey olmadı. Şuan 2000 mem 125 power ile kazıyor ama 59,29 mh veriyor.
bu hatalar neden karnaklanıyor yardımcı olabilecek var mı?
with this update" 0.6-209@210906 " 2DAY AND 0 Invalid Shares
work so good
How is it going with 1100 any rejections observed?
yes she is in danger lower the mem and cc lol cc = 1100 mem=MAX2500
Lol
3150 mem is over the max.
You people have no clue.
Your killing ur GPU.
1080 core
2600 mem long term.
You should get 62.4 which is plenty. Not worth 1.5 MH while sacrificing reliability.
Your numbers are so high and my MH isnt far off from yours. Learn how to tune them.
新人请问怎么更新 Nvidia 驱动程序
May I know why after I shutdown my rig, all my Asus 3070 fans still spin while AMD card’s fans stop spinning?
Are rejected/invalid shares from Trex miner displayed as circled red number in hiveos? (my rig: 0.6-206@210918, N 455.45.01)
Are they stable at those settings?
Not really. 2800 was too high.
I’ve settled with 1150 core 2600 mem 130 PL.
i dont get why people set PL when using absolute core clocks…
when using absolutes it uses whats needed which is usually a good bit less than what you set PL
plus. when using absolutes… PL does nothing anyway
