Keep smoking 420…
obv a joke and yes I may have exaggerated my mh at first, but you should try not to be so toxic while helping someone. Like I said, I’m new. I’m greatful the help, but next time leave out the the extra comments lol
So if I was you I’d be mining Ergo on those, they arent limit on that and Raven coin
Did you do the delay?
Hmmm
Try
1070 core
2600 mem.
If not you might have latency issues
You temperature are to high, please make a little bit cooler like max 50 degree and set 1100 and 2400 or 2450
same issue bro, I noticed an sticker labeled with LHR in the box… At the beginning I couldn’t believe it… seriously, its an sticker, It supposed not to be there.
I am getting 42 MH/s tops
is better than 32MH/s
I’d lower ur memory to 2600.
Keep your hasrate in the 62 range, 63 is great but not at the expense of over working ur gpu
ok i’ll try!
Hey guys, what do you think about the settings and temperatures of my ASUS TUF RTX 3070s? Before using negative clocks (-200 / -500), I think they consume more power that way. I want to read your opinions. Bye!
Leave it the way it is. Absolute core settings are there for a purpose.
Update your Nvidia drivers
Thanks @rkwjunior!
I just update the drivers to the latest version, and change the PL to 0 and the core to 1100. It looks stable. At the moment there are no rejections.
Last question @rkwjunior, what range of temperatures do you consider to be correct for GPUs care?
Greetings friend!
Wow. 106 watts on one of your gpu is crazy good.
I set my auto fan to 50c core temp. Then put fan setpoint to 0 in overclock window and reboot. They say anything under 60c is really good
hello I am new: what does mean: PL: 100w, 240w, 270w?
It the power limit in watts
Do you think?
GPUs are the new version of ASUS TUF GAMING (“OC”). They come with some improvements.
