Use absolute core on ur 2080s. Watch that power drop.
You have to look up which settings for absolute core on the 2080s, i dont know them.
Also id drop your mem to 2800. But check ur back plate temp.
Im running 62.8
I have just one RTX 3070 MSI Gaming Trio X and this is my config:
63.46 MH/s
Core: -600
Mem: 2900 (Sometimes i have to start with 2600 and increase it to 2900 after about 30 Min.)
PL: 130
2Miners
Do absolute core at 1100
Put ur Power limit at 0
Absolute core will regulate your power limit
So is it better than before?
Whats ur wattage?
Huge help man, thanks
Still having crashes about once an hour on gminer, nbminer, and phoenix . Lowered the mem to 2750.
Any ideas why I am losing connection?
You are killing your 3070 much before time if you keep those high memclock. E few cards can handle 2800. But overall the stable clock rate for 3070 is 1100 2400
Its all about memory temps. If you keep them low then high memory is ok.
I do 2700 mem
1100 absolute cor
0 power limit
50c fan set point. Mem temps in the 70s
62.46 MH dead solid.
3070 fans keep turning off and back on. never really going over 40%. brand new GPU and I have tried auto fan on and off as well as default settings
As long as it maintains 50c.
Running the same settings and they have been great but fan still turns off randomly. reboots every minute. min fan speed is set to 30%
Your miner reboots?
The fan does. I have all my devices set to auto at 60c and the 3070 is at 59c so the temps are good. But the fan should not hit zero, correct? min speed is set
If the temp goes below set point it may go to zero. Mine does sometimes even though my minimum is 25%. But as long as im maintaining 50c im happy
Great thanks again!
GA 104 error. Your system can not recognize the 3070 TI GPU. Most probably you have to upgrade mainboard bios firmware.
What of the 3070 is more cold? Msi gaming x trio / Msi ventus 3x / EVGA 3070 FTW3 Ultra ?? Please…
Gaming X trio is far colder than the ventus, and also more stable. I don’t know about EVGA
