RTX 3070 settings
@canmining i have them cold since they are at 65% fan speed minimum and they are in a rig that has a nice air mouvement
2900 mem is huge, try touching the back of your card and feel how she is suffering from that 2 mh/s that going from2300 to 2900 cost you
I can touch it, and leave my hand on it.
2MH per card is alot over months/years of mining.
Ultra Ftw3s i am surprised that it is not overheating the ram
Peak is 1500 mem clock. Im at 1450.
Fans running at 50% ish except the one on the end running 73%
Highest temp on backplate with infrared gun is 46c.
And thats the warmest card since its on the end.
Im not even running my rig fans.
do you store your rigs in a fridge ?
Want a picture of the infrared gun temp? Room is 70f right now.
I live in the northeast. Widows open at night and all day. House stays in the 70fs. If its hot out, i turn on 2 of the 4 rig fans.
Back plate temps, 42-46c depending where i point the laser.
i believe you, its just unrealistic from the hundreds of 3070’s i’ve seen
I have the same card and these settings work great but I am getting a little too many invalids. About 8 an hour. Are you getting any invalids/ how can I reduce this number?
I got 6 invalids on one card in about 24 hrs.
What miner are u using?
using Pheonix miner
Pheonix sucks. Use Gminer or Trex.
Well i got proof. Dont know what to tell ya.
Ultras are overbuilt. Great performing card.
Thanks, ill give it a try
3070 doesnt like cores to be negative whenever i have tried the same negative cores they ramp up the temp an drops down the hash rates OC i am using for my 3070 are
Core 1100
Mem 2500
PL 130
best stable 61.98 MH
Gminer is way more stable and my hash rate went way up. THANKS. but gminer has gone offline 4 times in 12 hours. I set watch dog to restart on a low hash rate as a possible fix but restarting that often is a problem.
Any ideas?
The last 12 hours?
Mine never shut down from what i can see.
I haven’t used the watchdog. Im confused how to set it up.
What 3070s do u have?
Put ur power to 0. That 130 should drop. It will regulate itself with absolute core clocks.
If you go to -500 core then ull have to manually regulate power.
Id set it to 120 PL
And 2800 memory
But this all depends on what card ur using.
My msi needs more power than my FTW to maintain over 62mh
Here is a screenshot showing the drops. Watch dog i just set the minimum hashrate to 50 so if it drops below it will restart. I did not do anything fancy with it
