LHR. They work like this for 5 minutes and then restart. I had to change the overclocking, and now they went down to 43.5 mh/s but stable.
Still experimenting with GPU0 (the most chilly one). Still cant get past 45.
The last GPU (GPU3) is somehow the weakest. Most heat with minimal MH/s (maybe because ingesting its friends exhaust).
MSI Ventus-x2. Tropical rainy season (damp hot) with 26-33 ambient temp.
Mcdimm whats minner used?
Thanks bro, I could get 44.5 Mh with my 3060 ti (with hynix memory) after used your overclock settings. I thought that the max value which I can get with hynix memory 3060 ti was about 40 Mh.
2miners with trex
someone has bios msi gaming x 94.04.6B.00.A2? some oc?
It is not the same bios, I can not exceed 42 mhs, no matter what I do
Keep trying until you gets 45 mhs each (its possible). You do still have below 60c on that hash where mine already over 60c so no more headroom for me
and turning up your fan speeds to a min of 75% cooler is always better!
Summer in Brazil can be hard some times… but 60c is not thaaaat bad tho. Using T-Rex. Everything updated. Also, Asus MINI and ZOTAC are shit cards. Can’t get past 1600 without facing invalid shares.
Here is my OC setting which is quite stable and I have been using it for a week so far.
I hope, it might help someone.
These are my settings using Nvidia driver 495.44 and T-Rex 0.24.8.
NBMiner gave me a drop in performance, almost 1 MH on each card.
T-rex miner
I have flashed palit rtx 3060 ti dual BIOS to EVGA BIOS, great improvement with higher hashrate and lower power consumption
