Sorry about it, i bought rtx 3060 ti online then arrive is LHR version. i really hate that. Trying to contact seller then no reply yet. first i test mining on windows its start with 53MH/s then drop to 23MH/s on ethash. i dont test on hive os yet because it take time to manage wire on my rig. about that it have chance to increase MH/s? anyone have setting about it? i feel growl about this seller.
well this LHR card does this yes, but you can push it to 35-37. Lolminer on the other hand made some boosts for these LHR cards and you have to use lolminer and it will do aroun 45 i think.
which overclock setting i need it? also recommend nvidia graphic card version on hiveos?
try with 1300 Core clock , 2300 Memory.
The model number on the LHR gpus end in “KL”.
Should have had the seller take a pic of the model number for you.
Mine something else with it, like Ergo or Raven, youll get much better hashrates.
i dont see any KL word on that. only see its write LHR. what is meaning if not have KL?
The end of the model number has 2 letters, either KR or KL.
kL Means light hashrates
I cant get more than 106mhs for RTX 3060Ti…can someone help?
The other algos are core demanding so you should increase a bit core clock. Test with hogher values increasing by 50 each step
RTX 3060 Ti (LHR) Gigabyte Eagle
I try everything and never get stable hash, this settings is best for now and work super stable!
nbminer 38.1
N 465.31
116.3 Mh/s 99-106w
900 2700 125
yeah right you get 115 mhs on 3060ti lhr
Ya, he’s probably talking about Ergo
For ERGO!
ETH mining
Gigabyte RTX 3060 Ti GAMING OC PRO 8GB GDDR6 - LHR for sure
nbminer v39.2, driver: 465.31, OS: 0.6-209@210831
OC: -480, 2800, 130
[10:41:06] INFO - ================== [nbminer v39.2] Summary 2021-09-03 10:41:06 ===================
[10:41:06] INFO - |ID|Device|Hashrate|Accept|Reject|Inv|Powr|CTmp|MTmp|Fan|CClk|GMClk|MUtl|Eff/Watt|
[10:41:06] INFO - | 0|3060ti| 43.17 M| 87| 0| 0| 129| 57| | 66|1005| 8200| 100| 334.7 K|
[10:41:06] INFO - | 1|3060ti| 42.95 M| 81| 0| 0| 129| 55| | 55| 945| 8200| 100| 333.0 K|
[10:41:06] INFO - | 2|3060ti| 42.97 M| 86| 0| 0| 129| 55| | 68| 975| 8200| 100| 333.1 K|
[10:41:06] INFO - |------------------±-----±-----±–±—±-------------------------------------|
[10:41:06] INFO - | Total: 129.1 M| 254| 0| 0| 387| Uptime: 0D 00:47:05 CPU: 3% |
[10:41:06] INFO - ==================================================================================
Is that looks well?
No eth pelo nbminer. Marca galax, memoria hynix.
Cc -300, mem 1150, pl 70. Gpu fica em medoa de 1100mhz. Com LHR 70 esta fazendo 42-43mhz com 139w e eficiencia de 300-310.
I don’t understand very well but i do some tweaks and now i have this with ETH
Total power: 300w from the socket
AVG MH/s from the pool: 79
Efi ~ 0.323
I am able to get table 40 mh on mining ETH. I am using NBminer, which unlocks 70% efficiency as of right now, possible higher in the future.
We are hoping …
NBminer’s and miniZ’s teams are working hard i think.
