I have “8” msi 3060ti’s running with Hynix and none of them want to even come close to what your screen shots are showing… any advice???image|666x500
Also my cards are dou gaming x
very nice. Yea I think those Samsung rams use less power
which miner are you using?
For MSI gaming X i just flash it with Ventus Lhr v1 version bios, after its start working with 42+ mhs
Edit:
Dont forget to safe the original bios for each card.
I’ve been able to break 47. I posted my data in another thread instead of this one not realizing the other thread was for FHR cards. My 3060 ti is a recently purchased evga card, not sure the mem type cause it’s currently running in my minterstat rig which doesn’t show mem type. When Mem much above +3250 and the card won’t come back after a reboot, it’ll take it while running though, I had it at 3400 for like 12 hours before I had to reboot my rig, I was over 48 with that and 150 power limit. Just wanted to contribute my findings.
settings are:
here is what MS shows for the speeds, clock bounces, mem is static speed
hashrate:
Please share at least 12-14 days miner stats, so we can see it.
36 min it’s not an achievement.
Breaking 47 its not a news. I saw some guy who manage 50mhs but only for 40-45 min. ))))))
For Palit RTX 3060 Ti dual, this setting so far is quite stable, has been up for 2 days without any crash
it’s been at this range since I’ve been running it about 2 weeks now, I moved it to a hive rig, I did have to reduce the memory a little bit for whatever reason. 3000+ it got wonky in hive, but still pulling similar hash with reduced mem speed.
Can you post your T-rex settings - i have the identical cards and under NBMiner am only getting 44mh/s
I have just updated everything on the machine - latest Nvidia drivers, latest HiveOS, latest NBmIner
How long have you had this running stable at this speed ??
Craig
Which miner you are using?
damned ! sure it’s not non LHR 3060Ti ?
I’d love to push my Hynix Gigabyte 3060ti that much… but I’m capped at 1750mem and 42Mh/s
I also think these are non LHR Cards and they can do 60 MH
