Wtf man hahahh that’s sick… I have a bunch of this exact same card…
No invalid shares/crash yet??
Nope, none. Been running like a champ. Holding pretty steady right around 47 MH at a temp of 64.
The only thing that may be different than others is that the card is plugged directly into the motherboard slots, no risers.
Exact same EVGA model haha but can’t get past 2300 on memory… But i’m happy with 44mh/s. Also, even 2100 I don’t know if it’s safe for the long term.
whats your miner?
lol miner or nbminer?
i have 9 palit 3060 ti lhr but on 2 of them i get invalid share every 6 hours
it crashes with my MSI Ventus OC V1 card
What OC are you using?
Cheers
MSI RTX 3060 Ti Gaming X
This is stable ?
You could reduce power consumption by setting a locked core clock instead of -502, for example, i use at my Gigabyte 3060 TI LHR 1425 core clock, and my power consumption is under 120W.
I tried locked core but got the exact same results. still 130W
Guys can you tell me if stable hashrate is better or variable? My hashrate keeps fluctuating between 133 to 135. But profitability has reduced recently (could be due to difficulty of ETH)
linikis did you have to accept force flashing to be able to put the bios of msi ventus?
Yeah, may the force be with you
you can share your setting please, and how many MH you get
linikis sorry I do not understand the translation well, I tried to flash it but it gives me an error, I did not know if it was safe to check “force flashing ignoring security check”
Your 3060ti’s are they duo or trio?
I found a solution to reduce my power consumption: Using GMiner now with --lhr_mode 0 (ernergy saving mode)
Result my Hashrates dropped by 5% wherby the power reduced by amazing 25% !!!
Try if it works for you.
Mostly I’m using locked core 1350, memory 2100 and pl 130
Have ventus, duo and trio. How can i help?
