Hi, bros.
How do you fight with incorrect shares? I see every 3060ti have a lot of them. I’ve changed mem and core clocks, hash rate drops but they are appears again and again.
BR
Hi, bros.
BR
Hi, there could be a couple problems: OC, RISER, BIOS, MB BIOS SETTINGS, or even wrong placed CPU.
And hi everyone again!
After long night, here is my new setting so far working good.
For MSI gaming X i just flash it with Ventus Lhr v1 version bios, after its start working 39mhs+
An an update:
I change the core value since it was very hot temps on a core. So after changing it to 1400, power usage decreased and I get more cooler option. But I loose a couple mhs. But no problem at least its more efficient
Hice
I will start checking mb bios and risers first
What is your Nvidia version ?
hi can u help me i tird setting for 3060ti lhr oc pro try memory 2900 2800 2700 2650 2600 try power 170 165 150 145 140 135 try core 1600 1630 i get invalid share after 2h or 5h or 1h :((((( now iwant try core -502 2750 120
100% Stable. Some Hynix GPU’s can’t overclock as well as others. Thats my case, the ASUS and ZOTAC can’t match the EVGA’s overclock. (ASUS DUAL 3060TI LHR MINI)
In my opinion, setting a PL is useless.
NBMiner v39.7
NVIDIA Driver 470.63.01
Thank you! I applied your settings and finally got both my 3060 TI LHR over 43
lolminer 1.35:
waths is different core - and +
waths is different -500 and +500 ?
Benim ayarlarım bu şekilde, dual mini değerini arttırmak istiyorum ancak rig düşüyor.Bu şekilde stabil çalışıyor.
Just posting to help others out with Overclocks. Not sure if I hit some strange silicon lottery with mine, but my Hynix has been going strong for 12 hours at almost 47MH/s @ 145W
Miner is ETHASH - T-REX
Hive OS version - 0.6-210@211112
Right now your ram is cooking dinner for you.
64 on core so its about, at least, 90-100 on a ram?
Are you sure you want to mine with this stats? for only +2 mhs?
Kinda risky.
10 degrees increase in gpu does not mean 10 degrees increase in ram. Cards have more than capable cooling solution, as long as gpu is lower than 70 it must be fine…
Maybe, but are we sure?
Since i have ZOTAC 70ti amp holo that normaly very cool card during the gaming, but under mining core is 43-47c but memory around 96-100c. And from my side is kinda too high.
In other hand i have 5700xt from Sapphire, that can cooling core for 40c and ram for 67c…
I still things that for 2mhs its not a good trade:)
3060//ti/3070 memory is different (gddr6 vs gddr6x) from the rest of lineup. also almost same size card uses much less power too, so I wouldnt worry too much about heat issue here for 3060/ti
Wow, what model? And any extra config on the miner?
EVGA 3060TI LHR XC. Nope nothing special with the miner. Here’s the miner setup. It also seems to have gone up after posting. Currently averaging 47.14 MH
Motherboard
PRIME Z390-P ASUSTeK COMPUTER INC.
CPU
6 × Intel® Core™ i5-8400T CPU @ 1.70GHz AES
Disk Model
ATA ADATA SU630 240GB
