Zdarova, can you share your telegram have a couple questions about ETH.
try CC1400 M2200 PL0 for the Hynix memory
Whitch miner and version are you using? do you put a extra config argument on it?
Anyone own a 3060 Ti LHR Asus, MSI or Zotac brand? If yes, whatâs the hash rate youâre getting with nbminer/trex miner unlocks⌠looking to make a buying decision soon and want to know which brand gives what hashrate. thanks in advance.
Strix - 40-41 mh
ZOTAC 12Gb 33-34MH/s
I have 3060 ASUS STRIX and 3060ti ASUS TUF (3 fan), Strix are samsung memory, TUF is Hynix memory, TUF is hard to work with, took me 2 days to get it to not crash my rig, had to settle on 1400cc 1800mc 130pl but strong wattage fluctuations (and after 24hr droped down to lhr1 mode) was making 38-42 jumping at start, now kind of stable at 40ish. Worst buy of my life, cant return either since boxes are opened
3060 works well on miniz otherwise, but hynix 3060ti is the worst.
GL.
THANK YOU - this helped a lot. my ASUS 3060 TI LHR with Hynix performs similarly to whatâs seen there, using Gminer latest.
hi, I might be the overclock. try to reduce the core and mem a bit low.
I have Gigabyte 3060Ti LHR with samsung memory, here are my settings:
ETH mining 42,5MH (LHR 68,5):
Core -300
Mem 2850
Pl 125
Dual mining ETH 25MH, RVN 18MH (LHR 35)
Core -150
Mem 2850
Pl 150
hynix is bad
Need to take time to adjust
i have ASUS RTX 3060TI LHR all kind and find the best answer
DUAL-MINI-8G
DUAL-MINI-O8G
DUAL-O8G
TUF-O8G
ROG-O8G
Asus Dual-Mini-8G 3060 TI LHR
Lolminer
Core 1470
Mem 1400
PL135
after update OC settings, wait for 5 mins âŚ
Hello, could you help me, I also have 3060 ti msi LHR. you have achieved some configuration for this âŚthank you
RTX 3060Ti: cclock: -200, mclock +1900, PL 130w = 39.7 mh/s @ 119w [E:333 kH/W]
RTX 3060Ti: cclock: +1350, mclock +1900, PL 130w = 39.75mh/s @ 104w â> gminer stable LHR2 [E:382 KH/W]
RTX 3060Ti: cclock: +1350, mclock +1900, PL 135w = 40.12mh/s @ 106w- â gminer stable LHR2 [E:377 KH/W]
RTX 3060Ti: cclock: +1300, mclock +2000, PL 130w = 39.24mh/s @ 85w-+>130w
RTX 3060Ti: cclock: +1300, mclock +1900, PL 130w = 39.12mh/s @ 100w â gminer LHR2 [E:391.27 KH/W]
Hynix with new lolminer 1.34 . I am very saitisfied wiht this version of lolminer.
Getting stable 172-173 without 3070ti.
does any have a palit dual 3060ti lhr, i canât get the right Oc for this card.
Two posts up
