HiveOn pool low expected income
50% less expected income for me as of this morning as well
No answers from staff? do we have to switch to nicehash?
Woke up tire morning, averaging 830 Mh to a daily payout cut in half to $26.85…. Wtf… has anyone tried switching pools yet or anything… this is unreal
my mining is well down about half normal installed latest update yesterday
average hashrate 133.03
earnings 0.00117 eth
It’s a known issue due to serverload. The following was posted this morning in Discord
Hiveveryone!
As you’re most likely aware, there are current stat issues on Hiveon. This is in part due to the increased server load.
The issue only affects statistics displayed and has absolutely 0 impact on your mining operations.
We’re working on it and will have it fixed as soon as possible. tools
All shares sent are still being accounted for and will be credited to your balances with a slight delay.
Apologies for the inconvenience!
@here
Here it is by half too…
the problem is how are we going to keep up?
time to change pool and os
Same as everyone else, down to about a 1/3 of my expected reward and falling.
However I am sure they are working on the issue which I believe is a front-end stat problem.
Actually, I have the same problem :(((
same here
it happend two times now at this point ill switch on ethash
Ну вот, сегодня ЭТО началось и у меня! При 530 MH/s HiveOn мне спрогнозировал 15-20$ в сутки, что в 2 раза ниже обычного! При этом все графики производительности ровные, без провалов. До этого, ~1,5-2 месяца назад произошёл обвал количества найденных шар в 2 раза, при сохранении хешрейта и вознаграждения. Теперь произошло это… Допускаю, что это связано с EIP-1559, но может быть это и сбой HiveOn.
Какие ещё предположения?
i have the same issue from yesterday evening – my expected earing running below 50% from what is reported to whattomine.com.
expect some answers
Looks fine now.
У меня пока не дотягивает. Интересно, что на других пулах?
not with me :unamused:
И на ETC тоже снижение выплаты в 2 раза, так что это проблемы на пуле.
Sorry to say, but my case it isn’t only the statistics display it is the actual income been reduced
To those that are still experiencing the API bug, thanks to @alph2k5, I and hopefully everyone else with this issue can rest a little easier now. Appreciate this information beyond belief. Gotta ensure I join the discord and turn on all notifications. Recommend if you’re able, do the same
