Anyone else seeing highly reduced expected income on HiveOn pool?
Got over 2Gh/s mine and seeing ~$60 expected daily earnings.
This happened a couple days ago as well.
Having this same issue over the past few days but especially right now the earnings are VERY low. Looking for answers.
Having the same issue here. 720 mh/s showing $24/day when it’s usually 50-60.
Yep I’m running close to a gigahash and seeing under $30 daily expected… Might be the last update… Seemed to go down a ton after install.
Yup. I went from .01/ day at just under 800Mhs to .003. Weekly i was at .1 now .02
Wtf is going on? I’m probably don’t with hiveon pools after this payout
hiveos update or network?
same here same hashrate but only getting 1/3 of normal payouts/day, been like it for the last few hours for me
Same here! Actually lower now…
Очень часто такое бывает в Hive! Мой ожидаемый доход снизился c 125$ в день до 30$(((
Is it bugged?
I’m expecting to see a tweet about it … It keeps going lower…, going to be at 0 soon.
That is what I was thinking. Seen some news about EIP-4488 to reduce gas prices.
I’m seeing the same reduction in projected earnings. I didn’t notice it a few days ago, but I track my actual daily earnings and didn’t see any change that concerned me. Makes me think (hope) that this is a platform bug that doesn’t impact pool/mining.
I’m thinking it’s a bug in the latest update… The difficulty did not go up that high or fast, and everyone I’ve seen affected is using hive so far.
almost 0 income today
check update from telegram channel. This is likely frontend stats display issue. From hiveos support: "Your shares will be distributed appropriately and your profits will not be effected. Please be patient as our team works on it :)"
thx i can go sleep now ^^
gs fees reduce but we don’t have the gas fees anymore they are burn, our incomes comes from the tips for the miner to speed up a transaction and the block resolution
It is not only the projected earnings been reduced. My actual earning is been reduced by half today
