Ну, вроде бы всё нормализовалось. По крайней мере пришло к адекватным значениям )). У Хайва такое время от времени случается…
Via discord:
TíasJørnesson — Today at 10:25 AM
@here Stats should be returning back to normal getting us back on track. Refresh, clear cache etc. If you’re having issues.
Thanks for hanging in there guys ;)) (edited)
I just switched to hiveon form ethermine. So hiveon is not off to a good start for me. I think I like ethermine better. So I have a question on how to get out of Hiveon. Do you have to wait until your balance hits the 0.1 eth threshold then stop you miners and switch? Right now I am at about 0.08 so if I switch now my 0.08 is locked in the pool forever?
I would mine to 0.1+ prior to the payout cutoff. Then point to the pool of choice.
There is no adjustment to payout threshold.
Hiveon Pool pays the transaction fees so they get to set some limits on how it works.
Each pool has some pro’s and con’s. Align your choice to your needs.
fwiw: Technically, if and when ETH 2.0 merge happens, the balances are cleared.
Do you like Hiveon? I just switched and obviously the reporting has some issues. but is the profit any better, worse or the same?
I always have a rig running on Hiveon, but my strategy requires a bit more payout flexibility so most of my rigs on are another pool.
Net: Hiveon has always been ± a few percent for me.
they said it will be counted correct but just displayed wrong, that is not how it is. I suggest everyone to check it. I will now search another pool and another mining os, because this is totally inaceptable. What happend to all those shares which have not been counted? They probably ended in some wallet owend by one of the guys from hive…
If you dont give me more details this is the last day I worked with your tools. Third time this happend. What to expect in the future? I think the same will happen more often.
Just think how much money that is, if a pool with 95TH/s workes into their own wallet with the full hashrate.
I think I like that ethermine has the polygon option too. Cheaper to move eth around.
30 days of side by side did not measure an improvement for me, but I was giving up the integration of OS level stats and Pool stats compared with Hiveon.
I am beyond free service levels and require adjustments in payout thresholds to support my plans or I would be on Hiveon full time. I’d doubt my limits impact most folks.
The ”daily expected” and ”weekly expected” earnings seem to have been corrected by now but not the amount of ”unpaid” (mined)!
This has to be corrected ASAP or i will definately switch pool AND never use this pool again!
1.12.2021 w nocy coś grzebali w statystykach. zawsze miałem 42-45$ a tu nagle wskoczyło na 75-80$ i rano już było 15$.dzisiaj jeszcze nie jest dobrze.Myślę że panowie programiści szykują się na zamknięcie biznesy i ładują sobie do kieszeni.
Miałem dokładnie ten sam błąd co ty @koparka1407.
Najpierw wzrósł ponad dwukrotnie, a potem gwałtownie spadł.
To, co zostało „wykopane”, zniknęło.
jak stracę cierpliwość to zmienię system, ,w ciągu 1/2 roku to już trzeci raz zmniejszają urobek.
Please check your income form the last day and compare it to the delivered shares. You will see that they didn’t pay all shares.
They delivered blocks during that time according to etherscan.
Check it on etherscan(Block Height:13726733)
HiveOn can you explain this:
the new stats do not match with the recorded hashrate and the delivered blocks according to etherscan
to już nie do kieszeni ale do worka ,znowu spada WYDAJNOŚĆ.
This looks very much like a scam, they don’t give any information to this topic
me too !!!
It seems to have been restored on my account. I have a hashrate of 946 MH and expected income of 0.01494 ETH now. Though more feedback on this forum by Hiveon would’ve been nice, it seems to have been resolved.
