Yes, I have the same issue here with no abnormalities found on my end. 1 GH/s seeing $22.87!?
Same here, 50% less!
Same here, but happening since September… the payouts or expected payouts received are about 1/2 from March…
Same here.
When I first start mining Eth on Hiveon my expected income does build to what I would expect.
However, over time (maybe 8 hours) it falls to about half even though my rigs are still mining at their full hash rate capacity.
I did not have time to look into it so I just switched pools. But I would like to get back to using Hiveon.
Hopefully, HiveOS will look into this issue and explain what is going on.
SO… here is a question… i guess they have fixed the catastrophic low profitability issue, but I am STILL noticing that my profitability is NOT what it should be.
On the main site, there is a dynamic statistic that states what the pool income per 100mh is … and it is right now at 0.00172132 ETH
I am running 877 mhs on the hiveos pool… so theoretically i should be getting
8.77 x 0.00172132 ETH = .01509ETH per day…
SO can anyone explain these numbers, and why I am at 0.01288ETH even with an average hashrate of 875 over the last 24 hours???..even at the average of 855 it should be .01471
My earning has been reduced again by half from 7pm. What is going on with hiveon pool. I might switch to ethermine after payout.
I’m currently running also running into an extreem drop in earnings from around 0.00840 ETH a day to now reading as 0.00344 ETH a day, continuing to drop. This is very concerning given my accepted share rate and mining rig hashrate of 482 mH/s. Glad I’m not alone, praying this is a bug in the API and not gonna result in days of lost profits
yes there is, I don’t understand why, normally 16-17 usd should come, but today it says 5-7 usd
Hi Everyone
I am having same problem for last 24 hours. My income is significantly reduced from 15 USD Per day to 5 Usd Per day. Does anyone know what’s happening. I only have 0.0487 ETH. Do i need to wait 0.1ETH for the pay out ? I really want to get my payout then switch to ethermine.
Hi
Even my rig is hashing at 890MHs.
Daily expected earnings are 58-62usd per day …
But from yesterday it’s showing me as below 40dollars per day . And now it’s 22usd per day …
Please fix this bug … hiveon
I would like to switch to ethermine too. If this continues for too long time
For last 3 hours not only expected also the incomes are laughable.
For 2 day I’m only getting the half , if you don’t fix it i will switch the pool soon .
This absolutely makes no sense. How can you monkey around with the earnings like this? Things are not adding up with the way the earnings can be upped and then disappear on a whim.
Same as mine
Any update on issue ?
It is still going down, I’d expect it will go to zero soon.
This doesn’t look good. At all. switching to another pool until this is sorted for better or worse
