Hello Korben,
It’s possible for you to send me the those bios?
My email: [email protected]
Thank you!!
Hello Korben,
Thank you!!
Hello Korben,
Thank You somuch
I use similar configurations, but what REF do you use?
Hi Korben, can you send me the Hynix and Samsung BIOS please?
Thanks in advance
Hello Korben,
It’s possible for you to send me the Hynix bios?
Thank you!!
Hi Guys, I have this setting and Rx 580 but I cannot make it work over 28,5. Could you please send me the Bios mod?
Thanks!
Hi, can you please send me those BIOS?
thanks!
Hi ,
Radeon RX 580
SK Hynix H5GC8H24AJR · 113-MSITV341MH.6M1
Would appreciate it if you could send me the bios that helps me to increase mh
Thank you
My cards… Any good BIOS? Listed are my cards and Hive OC settings… Send away to [email protected] if you wouldn’t mind… Many thanks!
Radeon RX 580 8192 MB · Sapphire Micron MT51J256M32 · 113-1E366CU-S5S
31.25 MH 1150 1 850/850/850 2100
Radeon RX 580 8192 MB · MSI Samsung K4G80325FC · xxx-xxx-xxx
31.21 MH 1150 1 850/850/850 2100
Radeon RX 570 8192 MB · XFX Samsung K4G80325FC · 113-57085STB3-M81
31.12 MH 1145 1 850/850/850 2100
Radeon RX 570 8192 MB · MSI Micron MT51J256M32 · 113V34122-F3
31.20 MH 1150 1 850/850/850 2100
Tengo la misma y no la puedo hacer rendir eso
[email protected]
Muchas gracias
Hi Korbe, please could you send me the bios for this card : Radeon RX 580 8192 MB · Gigabyte
SK Hynix H5GC8H24AJR · xxx-xxx-xxx
[email protected]
Thank you in advance
Mar
The polaris editor gives an error, could you send me the modified bios for mining
[email protected]
Thanks you
Mar
[email protected]
Thanks you
Mar
