Capo pudiste solucionar esto? yo tengo una RX 570 con esa memoria … estimo que es lo mismo …
Cómo quedó esto porque me da exactamente el mismo problema y encontré este hilo por Google …
Hola campeon, fijate la solucion que escribi arriba (pasar por el polaris) a eso vas a tener que ajustarle el OC… te paso mis numeros los cuales son estables desde hace semanas.
Core: 1190
DPM: 1
VDD: 850 (puede andar en 830 te va a consumir 2/3 w menos pero estas al limite)
MEM: 2180
Con estos valores , mas el upgrade que le hiciste en polaris tendria que estar rindiendo unos 32.27 MH, consumiendo unos 65/66 W.
Sigo probando, subiendo OC pero a la larga termina tirrando rechazos. De esta forma encontre la estabilidad.
Espero te sea util. Cualquier cosa chiflame.
Saludos!
hello friend I also have a problem with the Radeon RX 580 8192 MB · MSI
SK Hynix H5GQ8H24MJR 113-MSITV341MH.652
max 20 Mh / s can you send me a bios [email protected]
Hi @KorbenPapa do you have a mod bios the - Radeon RX 580 8192 MB · MSI Armor Samsung K4G80325FB · MS-V34114-F1
If you do. please send it to [email protected]
I have the same card as OP the armor rx 580 8gb oc mk1 with Samsung K4G80325FC · xxx-xxx-xxx
Starting to crash on me. Could you send armor vbios to my email please I’ll give those settings a go. Assume you also use Teamredminer?
Email: [email protected]
Ok I have taken the cooler off and confirmed I have SAMSUNG memory.
Hi Korben, have the new msi armor 8gb oc with memory (K4G80325FC · xxx-xxx-xxx)
Do you have bios and settings you run on teamredminer?
Email is [email protected]
Hi ,
For those having issues modding the MSI Armour OC (samsunf xxx-xxx-xxx as i was this is what i found worked for me.
download bios from rig
run one click mod but i did not install the faster straps (doing the faster onc’s just caused an error flashing the bios back to the card.
save the modified bios with slower strap and flash it to the MSI card.
i used 1175 / 875 (VDD) 2100 & 20 tweek
card running 48hrs @ 31.34mh 69w
may push it up a little and see what happens.
Enjoy
Hello Korben,
It’s possible for you to send me the Hynix bios for asrock rx 588 and Samsung bios for MSI Armor rx rx588?
My email: [email protected]
Thank you!!
HI BRO, PLEASE I NEED YOU TO SEND ME THE BIOS OF THE RX580 ARMOR (MSI SK Hynix H5GC8H24AJR113-MSITV341MH.6M1).
WHY WITH ITS ORIGINAL BIOS I CANNOT EXCEED 23.85 MHS.
AND POLARIS TELLS ME THAT IT CAN’T SUPPORT THE MEMORY
THANK YOU!!!
Hi, The polaris editor gives error -H5GC8H24AJ (UNKNOWN)-, could you send me the modified bios for mining , the name file is Rig_3186922-0-RadeonRX580-8G-SK_Hynix_H5GC8H24AJR-xxx-xxx-xxx- is a AFOX rx580
Thanks you
EDIT: I solve it use this room VGA Bios Collection: AFOX RX 580 8 GB | TechPowerUp
bye
Hello
I bought this card :
Radeon Rx 580 armor 8gb oc
602-v341-128sb1706001869 chk:ec5
I need orginal bios
Could you help me?
I have zero hashrate!
please I can’t make it go over 20MH I have this palca someone has the bios
SK Hynix H5GC8H24AJR · 113-MSITV341MH.6M1
[email protected]
Me está pasando lo mismo. Pudiste resolverlo? Muchas gracias x la ayuda. Saludos
Hello, how are you? Can you help me? I have a rx580 afox 8gb samsung. Have you got a modified bios?
Buenas tardes amigo, me podrias enviar la bios porfavor. Tengo una AFOX Rx 580 memoria samsung. Y no encuentro la manera que supere los 28.3. No llega a los 2000 la memoria
Hi Korbe, please could you send me the bios for this card : RX580GTS-1-RadeonRX580-8G-SK_Hynix_H5GC8H24AJR-113 Polaris give me an error. Please.
[email protected]
Thank you in advance
Paul
buenas tarde amigo, no, ahora gracias a un amigo de aca @amackata lo pude dejar estable en los 29,82, son samsung
