Custom Miner Integration
thank you !
Yes, i have for Cryptodredge.
You dont need a custom miner for this as this miner already provides ccminer compatible API. However there is a caveat it doesnt take json config file so you’ve gotta either manually put your wallet details in, or like what i’ve done, write a script to read the pools.conf json and feed it into CryptoDredge miner.
Oh so there’s no way for it to take hiveos’ wallet config then. Have you set it up to be able to launch from the hiveos interface? If so, how? Right now I’m having to run it manually from the terminal
i would love to use the customer miner with tdx-miner & z-enemy but i have no idea, the instructions provided assume you know how to use linux :frowning: myself & many others above would very much appreciate a video on how to use this feature?
Please help me.
Not working.
/hive/custom/mysuperminer/h-run.sh: line 7: syntax error near unexpected token newline' /hive/custom/mysuperminer/h-run.sh: line 7:
Лучше поздно чем никогда:
Судя по агент скрину парсится всё как положено.
Историю откуда тянет сайт?
post h-run.sh here please, or DM me
I not modified this files:
Config and scripts for Hive OS is here: https://github.com/GrayKite/minershive 74
Only copy to map.
well, then wrong paths or copy
XMrig-Nvidia for Hive OS, if some one interested (testd on GTX 570 :slight_smile: )
Can someone please post a video on how to add a custom miner?
You can open my integrations and see a picture where there is an example. Why do You need video? There you need to fill in only 6 fields!
Who wants to test xmrig-amd and xmrig-nvidia?
Custom miners are here: http://download.hiveos.farm/custom/
xmrig-nvidia moved to its own topic:
https://forum.hiveos.farm/t/custom-miner-xmrig-nvidia/7381
xmrig-amd moved to its own topic:
https://forum.hiveos.farm/t/custom-miner-xmrig-amd/7383
ВСЕМ привет,помогите установить майнер http://coinsforall.io/distr/xpmclient-10.2.2-beta.tar.gz
хочу помайнить XPM.по предварительным подсчетам профитнеее эфира…незнаю как карты себя поведут но рискунь можна.
570-0.36 cpd 580-0.41 cpd…пул с калькулятором http://xpmforall.org
Hello, i tryed to test xm-rig with your custom minet and haven, it doens’t work, tried with --algo=cryptonight-heavy
You put wrong parameters in Pass field which breaks miner command-line, so miner fails to run
You put in Pass field worker 5 which mean something like this -p worker 5, so miner think 5 is also command-line argument and fails because can’t recognize it
Thank you, i have been banned from pool :slight_smile: don’t know why, i have not overclocked atm
