Hi, i have 6900 XT and i get
how can i improve ? yesterday i get 63Mh with teamredminer… why now 58?
ok i’ll try this config.
now i get 56Mhs… with ur config… with default setting 58mhs…
Try with another miner, for example teamredminer or nbminer. This 2 are working good with my 6800XT.
Hi guys.
I am experiencing some unstable reported hashrate in one of my GPUs. What could it be? Maybe defective riser?
already tried and nothing 58 max…
Hey guys, thanks for neca OC settings, I have been able to achieve 64/63 MH with good wattage. Here are my settings if you guys curious. Thanks again neca!
wowww good MH and wattage
can show the template please ?
What miner did you use? I use Gminer and got constant at ~63.7MH
Team Red Miner, idk how configure another miner :’(
if i put to GPU 3 or GPU 5 Same OC , mHZ decrease…
selam mustafa bol kazanclar
Probably add more voltage and memory clock but that would increase wattage too.
Here is my result on 6800XT x 6 using Phoenix Miner v 5.4c
On 5.5 and 5.6 cannot detect 6800XT and if I use 4.5, the accepted shares are too low.
Normally does 63 to 64 Mhs
hello, show your card settings, consumption is low and hashrate is high, I am interested in the version of drivers and settings
