Sorry, should have been more clear, downgrade Phoenix Miner, perhaps try 5.4c
My rig has worked for 10 days nonstop, but yesterday, phoenix miner reboot by itself. Problem says Gpu * is not responding. So I tried to change miner from phoenix to different miner like teamred or gminer and its Fine. But tried to Turn back to phoenix, its still not mining. I tried 5.6a, 5.5c, 5.5b and also 5.4c
Dear Miners,
I switched the miner to the lolminer and everything is working. Thanks to everyone who responded.
hi neca
i admire your work.
but can you tell us which hiveos version did you use?
stable,beta or alpha?
what is your motherboard? did you use any specific setting in-order to get those results?
Good morning … the two are the best I got.
I think the Drive is not the best, because the 6800xt cards still have a lot to give, they are not being used 100%.
Please, HIVE programmers, develop a new DRIVE.
Neca, tens alguma 6900xt?
Hi guys, I have 3 topics for discussion, if someone could help, i’d appreciate:
Anyone here having problems using Phoenixminer? Hashrate went to zero. Did try some suggestions from another topic but still get nothing.
Do you have hybrid rigs with AMD and NVIDIA gpus? What’s the best way to configure the miner?
Noticed there’s Brazilians here. Any brazilians mining with Flexpool? How does it goes against Ethermine?
Thanks!
hey neca! Can you publish by any chance the complete settings for that one?
I have mine like that but is only reaching 63.5 with 150watts
soupn bem gostava…
All the information is in the previous topic of my configurations…
In response to the first question.
Uses Phoenixminer 4.5c for 6000 graphics, with beta version
- PhoenixMiner v5.6b (added support latest drivers for Linux. Notices: 1) this is Beta release of miner and added for testing purposes - need select version manually in miner settings 2) RX 6000 series “BigNavi” seems broken after epoch 412 in v5.5-5.6b: use v5.4c or other miners)*
Using now 6800XT and 3070 in the same rig, and it’s working perfectly with 2 miners: I’ve set teamredminer for AMD and T-Rex for NVidia. Both performing well.
Hi there i got this hashrate on my new 6800. Is it a good one or do you think i can do better ? I used to see between 60-64Mh/s on forums but i cant get it…
I xfx 6800 xt. but the memory clock cannot go above 1035? CRASHES.
I don’t know what to do It needs to be 1075 I’m using TRM.
Max. 60.50 Mh/s
I would love to get that instead of 53 MHS. I can get 61 on windows but hiveOS hates my Asrock.
Great, Works
getting 61.66 mh/s for asus 6800XT
