Has anyone been successful in decreasing the 6800xt wattage (in hiveos and confirmed at the wall)?
I have my Reference 6800xt stable at 63.4Mh, but it takes 150+ watts. seems like changing core voltage is pointless and does nothing.
Mustafa you sir are the man! I am using those settings on my 6800 xt and I got a jump up to 61.57 mh. I also set the power level to 125w in the settings you had your blank and it’s showing 122w for you for some reason. In addition, would you recommend the same settings for 6700 xt? Thanks in advance man.
Hi there,
Can anyone help to reduce the Temp for RX 6800 XT card? I have used the recommend setting from this thread and others are getting much lower temp as compared to mine.
I am using TeamRedMiner.
Thanks in advance for your help.
6800 xt in niveos does not work stably, always one card with a low hash rate, and after a reboot there may be another!
hi guys,
I’ve tried several config in this thread, I managed to lower the watt but the temperature is still high.
would anyone suggest what config I should use to lower the temp?
Check my settings below
Hey there! Can you share your config for those cards?
I am having issue using Phoenix v 5.4c…it is giving memory error, so I am using TeamRed Miner for AMD RX 6800XT and I am getting around 61 Mh/s. These settings looks good…would you mind sharing the settings?
Hi Guys,
I have tried so many different combinations of OC on my Saphire 6800 XT cards and they are not giving desired results
I am using HiveOn Pool with TeamRedMiner for dual mine ETh+Zil (Extra Config Config: --pool_strategy=min_epoch)
PhoenixMiner isn’t working with latest version and V5.4c isn’t giving stable hashrate
Also if few of you might not be aware that there is a switch on AMD cards for unlocking OC which is turned on in my case
With memory 1075 my cards are going dead after an hour or so and Rig restarting but no Rejected shares with 62.3 Mh/s… So i am testing 1060 now with less hashrate
can I get more details about the switch?
what does he give?
Here you go:
I do not see that switch on my AMD RX 6800 XT card. Maybe it is for the Sapphire model.
The best rate I get is 61.5 …I see some folks are getting 63-64 MHs.
The Gigabyte 6800 here is doing good. Very nearly the same performance + efficiency as my RX 6800 gigabyte cards on windows. The settings for his AMD card here are worth trying.
For his Nvidia cards, he should go for Absolute Core Clock settings instead. He won’t even need to do power limits.
I have this button even on my XFX RX 570 cards. Should be near the power cable socket or away on the same side of the card.
I have tested the card over night by changing the core to 1400 from 1370 and miner showing the card is dead after every hour. Switched back to 1370 for further testing.
So my GPU is going dead on even Core set to 1370 even.
Any suggestion please?
Can you shared detailed configuration please?
Hi, could you get an stable OC? I share my actual config where you also you can see the miner im using (teamredminer v.0.8.3). My GPU is Sapphire RX 6800 XT Nitro+. I cant down the power consumption and get also an stable mining without reboots. I leave it like this for days without reboots, see the screenshot. Tell me please if i can down the consumption.
Check out @RogerBizz settings above
But that one is Gigabyte. Mine is Sapphire RX 6800XT Nitro+. Im look OC settings for this GPU.
This is the best I can get now on HiveOS with 164w and I remember power utilization never came down on Windows as well using PhoenixMiner and it was giving 64.3 MH/S on 164w.
This is running since 15-20 hours now without any issues. I will increase the core to 1500 after 24 hours.
