@neca please share a print do your Full  OC page.
You have the best performance here until now.
Pt:  compartilha uma imagem com todos os parâmetros da sua página de Overclock. O seu foi o melhor até o momento.
Would it make any difference which brand you have? I have Asrock Radeon RX6800 GPU’s and I can’t get above 58.5 MH/s whatever settings I try. AMD-info currently says I have 1350 Core MHz and 1000 MHz mem.
https://forum.hiveos.farm/uploads/default/original/2X/1/158788441cd03cc2fa2d1915c5422bd98b9c492f.pnghttps://forum.hiveos.farm/uploads/default/original/2X/1/158788441cd03cc2fa2d1915c5422bd98b9c492f.png
Olá, montei recentemente meu equipamento de mineração e comprei 3 GPU’s RX 6800 XT Gygabyte.
Estou experimentando a pool da HIVEOS e utilizando o minerador phoenixminer.
Tive muito trabalho ajustando os parâmetros para conseguir o melhor de cada placa.
Porém uma delas eu não consigo o mesmo ajuste. Porque isso acontece?
Is it now possible to have a mixed mining rig, 6800 and say a 3070 with HiveOS?
Yes. I’m running 6800’s and a 3070
Are you running the stable version, or beta?
I’m still on beta (0.6-201@210323). I don’t know if it’s safe to update to the latest version
anybody tried the latest stable version with 6800’s?
Thanks. I’m on the latest stable version now
I’m on the latest build and I have a weird issue. I have 2x 5700xt and 2x 6800. With Phoenix Miner only my 2x 5700 XT mine and on TeamRedMiner only my 6800 mine. What could be causing this issue? I’m on the latest version 0.6-203@210426.
UPDATE - Switched to NBMiner and all cards now hashing
7 days ago I made a post showing the screen of my rig with 3 GPU’s RX6800XT running at 64 MH / s. Today at 13:30 all my GPU’s stopped mining.
Initially I removed the 3 AMD GPUS and installed an NVIDIA GTX1660 Galaxy GPU. I started my rig and it works normally.
Was there a change in HIVEOS for the RX6800XT?
When I start the CPU and the HIVE OS starts the GPU and recognized, there is a connection with the pool, and suddenly it passes a lot of messages in white quickly that I cannot read. How do I view the hiveos boot log?
What is happening?
My mining is stopped !!!
I am also having this problem with the phoenixminer on an RX 6800 XT.
Thanks for the info i’ve switch to nbminer too and all cards hashing…
Which OC are you using on the RX 6800 XT mining on teamredminer?
I am currently with 60 MH
I think it’s an issue with phoenixminer. If you downgrade to earlier version, people have reported this fixes the problem.
I have same issue. Which version? Phoenix’s or hiveos’s?
