Hi! Nice hash with low power. I have the same with same settings but wattage 128W. Which miner do u use?
My miner is lolminer on hivenpool
My miner is nsfminer / card is PowerColor
nice :slight_smile:
Thanks mate it really help. I had many issues with 6800 XT. This settings works. It was 58 before now 63.
So far the best for XTs … Who can help me the most to improve?
1111
:rocket: :rocket: :rocket: :rocket:
hi neca! could you please share your settings? thank you!
hi all! do you know how to translate below text into the settings on Hive OS
I got the text here : link
Thank you!
Memory +150Mhz, Fast Timings -ON
Radeon RX 6800XT - 63-66Mh/s 250W
The next step is to reduce GPU power consumption
Memory +150MHZ, GPU - 550MHz (1450Mhz), Fast Timings -ON
Radeon RX 6800XT - 63-66Mh/s 170W
here is what i got with the settings from mustafayuzuak
thank you!
Dears. I have 6800 XT but after a few days system shows high LA and stop miner or restart. How can I fix this?
OC was
System shows
Below are the settings that consume less power, if you want to try them. Of course the mh value decreases a little
The settings I just shared are very different from yours, if you want, make a note of your own settings FIRST, THEN try the ones in this.
thank you for reply! i want more mh 63-66mh. Do you have any idea what should be the settings for 680 XT?
thank you!
This is the best I can get for my 6800 xt and 3070… any suggestions for tweaking OC settings?
For 6800 XT;
We have a slight difference of mh / s ( 0,30 MH/S), but your electricity consumption is too much for me ( 35 w ). Is it worth the difference?
Managed to get over 63MH with 146W
Not sure why my electricity consumption won’t go down though.
any replies ?
What is your core clock for the 6800xt? I can’t read it because the yellow circle is around it. You really lowered the watt usage :relaxed:
