I started setting the most common core value 1250, and with 1075 memory clock but i immediately got a crash, so restarted with 1074 and no-crash anymore but low hashrate. So here, while mining i move the mem clock down to 1mhz per step and write down the hashrate i get, this way until i realized under 1064 i was getting less and less MH.
I actually look hashrate and power usage both.
The priority is given to the core voltage, not the core, because it’s the mV the core works that affect the power consumption the most.
So i started moving down the core voltage starting from 700mV decreasing it be 10mV-step.
Meanwhile I note the hashrate, which usually fluctuates.
Here i started from 900 on SocVDDmax and decreasing by 5.
NOTE: the other SOC Frequency, seems actually does not affect hashrate, even power usage, at all, like it does on RX 5000 series.
Every time i move something i let it mine for a while, and note down the results in terms of MH and power.
In the last i didn’t move the core clock a lot tho.
Moreover, to keep things more stable i set the eth_config into the teamredminer parameter equals to 1056, this helps me a lot because in this way i block teamredminer to “adjust” the gpu tuning.
