6700xt General Discussion
@Alligam
This is the best I get 47+ at 118w
I got mine to work after installing fresh image.
but now diff problem, a lot of invalid shares, no matter what I do, by default.
I don’t know, maybe need flash new bios? HELP!
Thanks Bro, I do self upgrade but does not work. So I need to reinstall, Right ?
set this settings !
yes with rufus make a fresh Hiveos usb key
download your rig.conf file in the hiveos folder after flash
deploy the last stable version !!! from scratch…
no update a fresh install with rufus
I’m watching it. but damn I got only 30 MH.
Did I get unlucky with card?
I’ve noticed my memory temp does not go up as yours
@arkeyn Try raising your Core Clock …i just raised my settings to 1300, not all cards took the setting on my rig, but they all went up to 45+Mh/s… like this:
Also… you should perhaps change to TeamRedMiner, and not EthMiner.
I’m getting a bunch of invalid shares, I have a couple of 3070 with one 6700
Then setup for mixed mining…
(You do this in FlightSheet configuration)
trying. doing same as you. except for pool.
can’t get miner to start… should I use same pool as you?
I’m running without GUI mode, can that be a problem?
my AMD is primary card
I had this as well when i did the change to mixed mining. Which Pool you use dont matter.
Just run through your config, Watchdog settings, Autofan config, Flight sheet, and specially overclocking section of the worker… notice that you now can tune for Nvidea AND Amd devices on the same rig.
Once this is done, start a shell to the worker, and run the command “miner”… if it runs you will see, if not, type “miner start” in the shell window.
Oh… remember a reboot never hurts :slight_smile:
Also in Overclocking i created this Currency specific tune:
pain in a butt, I’ll give try when wake up.
for now will use old miner
Thank You!
Hi :wink:
The RX 6700 XT Sapphire graphics card are well recognized with a new installation of hiveos (memory was not recognized with an upgrade)
Now I have a friend who will make me the settings and the modification of the bios, I will keep you posted for the hashrate
what miner are you using?
can confirm that using different miner solved my problem
congrats everyone!
Thanks. I just did a fresh install of 0.6.22 stable last night before I posted and it finally gave me the card name – but not the memory. Will work on it more tonight.
Thanks – I believe that I did a fresh install last night – which finally showed card name. Wondering if my ASUS card needs to be added to the list.
If you have any solution for modded the bios it can help us :slight_smile:
i use teamredminer
