I’m on the 210331 Version that Supports the 6700xt. I tried to use gpu fan find and got the Massage “can not Match card id” any if on how to fix that?
Is your card recognised completely by hiveos? Mine is just showing up with ne name and the rest is xxxxxxxx
Any settings? I tried one from this post but I’m having invalids.
This is the wrong version. It is partial.
You need to install a new version of HiveOs
[hiveos-0.6-202-stable@210401]
https://download.hiveos.farm/latest/
yes, card is recognised by hive including memory, did you get it to work?
Anyone got some good overclock settings? Can’t get above 43,5 in windows it get 47,5
what do I do here?
I didn’t touch anything yet
I was able to start
but can somebody clarify
why it’s low ratio? and what it is?
Hi Bro, I have updated 06.202version, i can detect 6700XT but unknown DDR6 RAM. How can i do ? Thank you.
I had the same issue with unknown memory.
You should download new stabile Image called: [email protected]
Sorry, no idea. What does your flight sheet look like? looks Iike you have mixed nvidia and amd - need different miners configured then
I’m using only one FS.
should it work both for AMD and NVIDIA?
Sorry, I probably sent you on a wild goose chase. If the miners supports both amd and nvidia you only need one minder afaik.
reinstall from stable version directly
it works for me , same issue as you before
Currently HiveOS 0.6.202 is seeing the 6700XT but not the memory – so I can’t run a miner. Back to windows for now
