1075 is the absolute max memory setting possible, your GPU may not be stable there for a number of reasons. Lower the Memory setting.
Anyone here experiencing this? Quite a significant drop on wattage and is constant.
6700XT MSI Mech 2x cards.
These are the settings I have got configured. Any recommendations?
Thanks! Im giving this a shot on my 1 6700 XT MSI Mech with Samsung using TRM. Hashrate initially dropped a few tenths but the wattage seems to have significantly dropped. Have you gotten any GPU DEAD errors with these numbers? Currently sitting at 46.4 mh/s stable 81w in Hive.
здарова вем,купил я на олх карту 6700 павер колор на памти микрон,и теперь мучаюсь,перепробывал много настроек по розгону.выдает 120 ват и от 46 - 50 мн но через время показует 97%ефективности и вырубается.
isn’t your memory clock too high?
Hello, I am new to this business but I have 12 GPU AMD Red Devil 12GB Micron, the problem is that I was restarted every 4 minutes and after the changes I am now restarted every 20 minutes or 1 hour my message is dead GPU.
Can your help me…
Try mem 1074
I’m worried about this part because the GPU has now changed my name I do not know what is happend can i know why?
looks like there 12 bricks now
Thank you I will Aplly the tweekers…I am from Ecuador I am doing my first RIG as my project I build it with TB 360 BTC PRO 2.0 — 8 GPU---- 2 RX 6600 - 4 RX 6600 XT – Y 5 RX 6700 XT… i am still looking for the exact configuration to mining… your video help me a lor if you wish to help me i will leave my email address [email protected]
Hello
I have a problem with the gpu 5, after 8 hours or less I get the error GPU DEAD, I tried several overclocks, other miners and the problem persists, it worked 1 week without failure and then the problem started.
What I noticed is that before failing the consumption of said board drops to almost half of the others. Could it be a riser problem?
Anyone running this TONDUAL on lolminer? Curious what settings you’re using.
using my regular eth settings, but ton isn’t great. You could try a faster core (and probably higher core voltage), but not sure it would be worth it.
the power is really high. Not sure a bit more is worth pushing the card that hard
